Is my clutch slave cylinder bad?
Old Mar 7, 2010 | 09:34 AM
lunatics209's Avatar
Default Is my clutch slave cylinder bad?
Ok. Well I have an h2b and I'm having problems with shifting now. It only happens when I race. When normal daily driving no problems at all. When I try to race, after one run then the clutch pedal would stick to the floor and I won't be able to go into gear. I'll have to pop it back up with my foot. This happened once but I wasn't the driver so I took the car for a spin last night it happened again.
Old Mar 7, 2010 | 09:45 AM
nsxter's Avatar
Default Re: Is my clutch slave cylinder bad?
well if its not leaking any fluid then there is only to possible problems slave cylinder or clutch master cylinder , but the was a thread on here about h2bers having shifting problems at high rpms
Old Mar 7, 2010 | 09:50 AM
I just checked nope, no leaks at all. I can race once without any problems but not again. If I'm daily driving it will be as if nothing is wrong. I guess I'll look into the slave and master cylinder.
Old Mar 14, 2010 | 02:56 PM
skyliner186's Avatar
I have the same problem!!! But I have a leak, because after 2 days the fluid drains and the pedal gets stuck. I found out there's a leak around the slave cylinder/adapter.
Old Mar 14, 2010 | 04:09 PM
itslogz's Avatar
Positive theres no leaks? Mine was doing this and i discovered it was a leak in the seal in the slave cylinder inside what the little boot covers and i could see a little that had leaked down the tranny. Replaced the slave and never had a problem again.
Eg_mE
Feb 1, 2009 10:34 AM
Honduh Uhcord
Oct 15, 2007 08:29 PM
SloCivicHMM
May 12, 2003 01:57 PM
integsra
Jun 25, 2001 06:48 AM
