My new DC4
I picked this up for 2k the other day.
LS with a Gsr tranny, needs paint and motor mounts.
Ultimately i would like to drop in a clean b20 from hmotors and piece together a turbo kit.
My shitty updateS!!!!!!!
new uncut front bumper
no more shmurf seats
stock spoiler so my trunk will stop leaking
Also got a new Clutch master and slave, and fuel pump and filter :D
The bad!
A Lady rear ended me at 3 am when i was pretty crunk, she was in a jeep wrangler
i let it slide
No idea why or how this happens. ****ing ebay its got skunk2 in the back but thats it
Does anyone have any idea what that yellow plugs in at the clutch pedal is for? its unplugged and a wire going to both the pins.
The bad!
i let it slide
I forgot to mention when i got it i put an apexi dunk cat back, skunk2 coil overs and a cheapo cold air intake. Got a header but the flanges dont meet up under the car.
but its your car, but from what you have, i think you should build off of whats there, not only because of reliability, but also because its more cost effective.
thats a waste IMO. you already have the ideal set up. LS is better for turbo and you already have a gsr tranny. why buy a b20 when their not nearly as reliable as any b18. if you were to swap the b20, not only would you need to build the entire block, its just not worth the time when you can make your current setup work just as well, and IMO better then any b20 setup.
If u guys didnt notice in the video when im under wot throttle i get a vibration in the car and it makes a weird noise sounds almost like the flywheel needs to be surfaced or its off balance. (Atleast thats what im thinkin) Also when i disengage the clutch pedal and let it freewheel it makes a funny noise like a metal surface rubbing against the clutch pads or somthing. As soon as i push the clutch in it goes away. The clutch has about 4k miles on it or so I'm told. What should I try to so to fix this? if u want i can make a video of the noise
Edit: Oh and i cant really do 0-60 my mounts are bleh and i havnt even spun the wheels in this car in fear of making it worse.
Ill go ahead and 4th that turbo advice
only because the b20 is essentially an overbored b18, so the walls are like paper. Because the b18 walls already arent that thick to begin with.
you were "pretty crunk" and you were driving? as in, driving under the influence?
Post this stuff in the right areas - either the Integra pic thread stuck at the top of this forum, or in the Appearance/Cosmetic forum.
