HELP (CAN I USE A CIVIC 92 MPFI)
Old Mar 6, 2010 | 08:49 PM
wunest's Avatar
Default HELP (CAN I USE A CIVIC 92 MPFI)
TRYING TO USE A MPFI FROM A 92 CIVIC ON MY 88 CRX. IS THAT EVEN POSSIBLE?
Old Mar 6, 2010 | 09:01 PM
D16SiHatch's Avatar
Default Re: HELP (CAN I USE A CIVIC 92 MPFI)
use a mpfi what? there are many components you can use. i assume you mean the intake manifold though, in which case yes you can use that to do the dpfi to mpfi conversion.
http://hondaswap.com/swap-articles/d...writeup-49557/
Old Mar 6, 2010 | 09:04 PM
wunest's Avatar
CAN I ALSO USE THE DISTRIBUTOR FROM THE SAME CIVIC OR DOES IT HAVE TO BE AN SI CRX DISTRIBUTOR
Old Mar 6, 2010 | 09:08 PM
wunest's Avatar
BUMP
Old Mar 6, 2010 | 09:21 PM
D16SiHatch's Avatar
you can use the newer distributor, but only if the ecu is also obd1.
since you are just converting to mpfi at this point i imagine you are not trying to convert to obd1 as well. that being said, you will need to get an obd0 mpfi distributor.
Old Mar 6, 2010 | 09:39 PM
wunest's Avatar
THANKS THAT HELPED ALOT. I THINK I FOUND MY PROBLEM. I DID EVERYTHING BUT THE CAR WONT START. IM CURRENTLY TRYING TO USE THE OBD1 DISTRIBUTOR.
Old Mar 6, 2010 | 10:43 PM
DCRB's Avatar
yeah you can't mix obd0 and obd1 parts. you have to use the full on obd0 ecu and dizzy or the obd1 ecu and dizzy together, no mixing and matching.
carlthecrx
May 13, 2008 02:08 PM
TurboAngst
Dec 2, 2007 10:29 AM
fin781
Jan 19, 2007 09:16 PM
89hatcher
Jun 5, 2006 02:01 AM
ONEFASTJDM
Apr 1, 2005 01:50 PM
