VSS connector question
Honda recommended me to change the whole harness since the VSS connector
is corroded. Is their away to fix the problem without changing the whole harness?
CEL is on due to this. And the job to change the whole harness is really expensive.
i don't know of any place that sells the connector alone but i'm sure they're out there. as for year. i believe 94-00 civic has the same vss connector. you may have to remove the white spacer inside if the connector doesn't fit.
EFstyle
39
Sep 10, 2010 09:53 AM
mr abstract
26
Sep 28, 2006 12:43 AM
jdmekrsi
Mar 14, 2005 02:12 PM
