H22A hybrid in civic....will not start. HELP!
as title says,
we just installed h22a into 93 civic coupe ex (ej1) and have everything ready to go.
just fixed fuel connection problem i had earlier with no fuel leaking.
thing is, when you crank the motor, the flywheel spins, the starter spins, yet it won't start. we checked for spark (we took put the spark plug and put it into the spark plug wire on all 4 cyl's and WILL spark when put next to the frame, but will NOT spark holding up the spark plug with it inside the wire)
is this normal?
and i don't know if fuel is being delivered...please help!
is this normal?
I had the same problem in my civic when I installed the H22. First thing to check is are you pushing in the clutch when you try and start it? 2nd thing is to make sure your wiring is correct and all your sensors are hooked up especially your KNOCK sensor it will not start without this hooked up. I have seen alot of people do this swap and it wont start at first these two things are THE MOST common problem, especially the KNOCK sensor. Good luck I hope this fixes your problem so you can go smoke some v8 ***
they wont know what hit em
they wont know what hit emThread
