Weird stance with ITR springs/shocks on eg
The passenger side is sitting a good 1" higher on my eg. Setup is OEM ITR springs and OEM ITR shocks front and rear (including ITR rear lca's). Everything else is stock. I had switched to this setup last October (about 5 months ago) and I was hoping it would even itself out but that doesn't seem to be the case. The car rides great and I would like to keep this setup but the stance is bothering me. It's almost time for me to switch to the summer rims so I'd like to figure something out before I make the switch. The drivers side looks like where it should be but the passenger side is almost higher than stock. When I swapped the to the itr stuff I also replaced all the front lca bushings with oem ones, new upper and lower ball joints, new tie rod ends, new trailing arm bushings, and a full alignment. Any suggestions?
I've also thought that maybe it's not an ITR spring. They all had similar markings on them and the stiffness on each corner seems to be similar though.
Does anyone know if I'll be able to get the spring back on the shock without a spring compressor if I take them apart? I've never had luck with spring compressors on Honda springs because the coils are so close together. I've swapped springs and shocks a hundred times but never with oem springs so a compressor was never needed. I'm thinking about switching the two springs around and see what happens. I'd also have a better idea if there are really the same springs and if the shocks are good but I don't want to be stuck not being able to get them back together.
No, I agree, they do not looked centered. I've had the car for five years and they have always looked like that, never caused any problems though.
Is that a caster issue that causes that? I had a full alignment about 5 months ago.
I'm not sure where I read it as it was years ago, but I always thought the ITR suspension was corner balanced to the cars stock weight.
im not tryna bs or anything but that just reminded me when i had the stock shock/springs in my itr it looked like it was crooked like the left side was a little lower
I'm thinking I'm going to try switching the springs. But does anyone know if I'm going to be able to get everything back together without a spring compressor?
try swapping the struts in the front.. like stated above their is a spring that goes on the tranny side and one that goes on the engine side.. the itr is corner balanced
lol. No, maybe the guy who had them before me was though. It sat like this since I put them on my car. I'm 6'1" and about 180#.
As far as corner balancing is concerned. Everything was assembled when I got them and the fronts are side specific. I'm going to take them apart next week, I don't know what else to do.
How positive are you that the ITR was corner balanced from the factory? I thought all the rates were equal at 250#. Are the two front springs different heights?
it suppose to be a tuned suspinsion on the r.. i dont think its a different height but a different spring ratio cause of the motor being heavier than the tranny side.
take you like 20 min to find out i say its worth a shot
https://honda-tech.com/forums/acura-integra-type-r-8/what-stock-springrates-1997-1998-2000-2001-itr-278719/
You'll able to adjust the perch height on the shocks so you shouldn't have a problem.
That's interesting. The rears do not look like they would be progressive springs. I do question how accurate that info is though.
Don't you have itr springs? Does your car sit even?
Stock ITR spring rates from an OLD OLD thread in the ITR forum.
https://honda-tech.com/forums/showthread.php?t=278719
i thought the ITRS had linears in the rear? Its because your motor is sitting on that side and your tranny on the other. Which one weighs more? My car is also at different heights right now because of that reason. About .5-.75in difference in sides. O well, still rides and handles great.
Yeah, I know that the car is going to lean a little bit but this just seems pretty extreme. Between my eg and dc I've had H&R Sports, Eibach Sportlines, oem dc, oem eg, gc's with Illuminas, and now this itr setup. All the regular springs (non adjustable sleeves) have sat relatively evenly.
I'm going to swap the two springs on Wednesday and see what happens.
Yes, ITR rear springs are progressive rate.
Here's my stock Integra rear spring (top) and ITR rear spring (bottom)
I only have the ITR springs on the rear and stock GS-R springs up front with the Koni perches on the lowest setting, and the car sits pretty much even all around, except the front left is about 1/2" lower. It's not really noticeable, though.
Well the results are in.
They are completely different springs and shocks.
on me for not paying more attention when I installed them.
I have no idea what either are but they are definitely different. (passenger side on top & drivers side on bottom)
Luckily, I had these laying around so I threw them in there for the time being.
This is what I have the in the rear. I don't think the springs are ITR springs but at least they are both the same. The shocks are ITR though. Anyone have any idea what they are? I'm assuming they are OEM Honda springs of some sort.
Ugh.. how annoying. In the near 100 times I've purchased something on ht or ebay this is the only time I've been screwed. I guess I was too trusting and didn't look close enough at what I had even gotten. At least I only paid $100 for everything.
idk what I'm going to do now. I think I'm just going to roll on the GC/Tokico's for the summer and figure it out in fall.
on me for not paying more attention when I installed them. I have no idea what either are but they are definitely different. (passenger side on top & drivers side on bottom)
you didnt swap them over just to see? the thicker one may be that way for the weight difference from the motor side to the tranny side.. cause even on a coilover you always have to lower the tranny side more to even the car out
