d16 idle problem
ok. my set up:
92 hatchback
d16z6- full rebuild
t3/t04 turbo
750cc injectors
p28 ecu-chipped with crome
My problem:
When i turn the car on it starts up just fine and idles around 1000, when i give it gas it'll rev up then bog down a bit then idle fine again. now when it get up to normal operating temp. it'll will either just shut it self of or ill give it some gas it revs up a bit and then dies. Ive checked all my sensors, fuel pump, dizzy and spark plugs, and i don't know what else it could be.
any ideas?
92 hatchback
d16z6- full rebuild
t3/t04 turbo
750cc injectors
My problem:
any ideas?
i tried some plugs i had laying around but it didnt really change anything. but i ordered these to day any will try it again when they get here.
how am i supposed to go about messing with my mapping and such.
update:
i got my new plugs and gapped them correctly. started the car up and same thing happens, give it gas and it was to die. are there any other possibility's besides getting a re tune cause i want to keep that for last.
well im back. car isnt even running now. i put in a new vtec and o2 sensor subharnees from rywire.com for the codes. i have the colders plugs in everything is on correctly. the car will turn over and over and over but just wont fire up. what else can i check or do to fix it?
thanks for all the help
SuM Honda
Jan 1, 2010 07:29 PM
nosbocaj
Jul 30, 2008 07:23 PM
EG6AAARRR!!!
32
Jun 19, 2007 10:57 AM
