any review of a turbo R??
Is anyone out there with a boosted R can give me a good review of performance, reliability, gas milage etc.... any 1/4 miles times with baseline drag 3 kit
here's some question I have for my fellow boosted R
Will the R engine hold a drag 3 turbo kit with walboro fuel pump, 320cc injectors, 12.1 fmu disk, 3 inch full exhaust running 7psi with little tuning of cam gears and fpr
do you have to retard the timing
how long has the stock R engine hold up with 7psi of boost??
thanks
thanks
Do a search next time. I found lots of threads to look through:
https://honda-tech.com/zerothread?id=185940
https://honda-tech.com/zerothread?id=178506
https://honda-tech.com/zerothread?id=172217
https://honda-tech.com/zerothread?id=157417
https://honda-tech.com/zerothread?id=155955
and the short gearing is great for building boost
It is.
It is.
Well there is one good thing about boosting an ITR.....You dont need a shift light you simply shift everytime you hear massive detonation
tell that to Zygspeed, or turbor481, or any of the other turbo charged ITRs on this board.
I didnt say it couldnt be done Im just saying the B18C5 wasnt ever intended to be boosted. Everything about it was designed to make N/A power...EVERYTHING
Rguy, who drove 6 hours round trip with TurboR481 at 80mph+ with several high speed boosts, and his car is FINE.
turbo R's suck
so - your point is?
swing by some time - see if you can hear the detonation in my car over the 60mm wastegate
[Modified by TurboITR, 1:36 AM 9/9/2002]
Sure if you have a tiny turbo with low boost and a small powerband. Otherwise take a guess why a pro turbo honda ex: papdakis shifts twice in 1320 feet and hits traps at 180mph. Short gearing right?
Thanks for your insight.
[Modified by Reid, 8:34 PM 9/8/2002]
Yes, a turbo ITR and Steph's car make a very good comparison.
Mine is running like a top now. It's only at 5 psi, stock plugs, stock timing, stock injectors, 12:1 FMU, stock exhaust. It pulls HARD and it is a blast to drive. I'll be running the 1/4 mile Wednesday and will post the results here, dyno charts hopefully next weekend but I'm a bit poor right now.
HTH
M
HTH
M
Take the time to tune your engine correctly and you can make it reliable. Slap on a turbo and crank the boost up to 10psi without taking the proper precautions(tuning) and expect to destroy the engine.
I only know of two honda engine designed for boost, ...
It's a V6 F1 motor from the mid to late 80's, putting out from 1000-1500? hp from 1.5 L , depending on boost settings (I hear they ran 4 bar or 60 psi at times)
And just 'cus I'm in a good mood, I'll only post the link!
http://www.we-todd-did-racing.com/we...EzZGZkMzF5NTQx
[Modified by Zygspeed, 7:14 PM 9/9/2002]
factory goodness!
