2.0 LS V-TEC build
I plan on throwing a little something together for the summer time until my fully built boosted GS-R is done. I have an LS block and a B16 head. I'm gonna sleeve the block to a 2.0 with an 84mm bore along with the stock LS crank and LS spec rods. This is a rough rundown of the parts list I was going to go with.
LS block 84mm AEBS
Pr3 or ITR pistons
LS rods
B16 head some port work ITR springs and retainers, ITR cams.
Skunk2 Intake manifold
Not sure what size injectors
Adj cam gears
I was thinking Bisimoto headers
2.5 " straight through to a Vibrant muffler no cat
ARP hardware
Keep in mind this will be a daily driver. I want you guys opinion on what you think this will make for power?
LS block 84mm AEBS
Pr3 or ITR pistons
LS rods
Adj cam gears
ARP hardware
5 angle valve job........ valve job is THE MOST CRITICAL part of head flow.
how high do you want to rev it? if you arent going to rev it very high then dont worry about arp fasteners(except head bolts/studs which are a good idea on anything)
injector sizing depends on HP.
my guess would be that you would be looking at somewhere in the 170-190bhp range(at 10-11:1 although i have no clue what CR this setup would have)......which would need somewhere in the 280-320cc/m range.
dont even worry about adjustable cam gears.........not on a DD.
Rex89
Jun 27, 2007 12:37 PM
