Fuel line help
Old Mar 5, 2010 | 02:07 PM
blackdoutrsx's Avatar
Default Fuel line help
So my car is throwing a CEL 16 so im going to be replacing alot of the fuel system, however my first project was changing the fuel filter but last night when i tried loosening the bolts that hold the fuel lines in wont give. ive tried soaking it with WD40 for 24 hours just about every hour and still no luck. Does anyone have any tricks?
another option is probably going to be just replace those fuel lines as well, being that i can even get them off the engine and firewall. Does anyone have a good link to buy some replacement lines preferribly OEM or braided lines will work as well. Thanks for the help.
Old Mar 5, 2010 | 03:14 PM
Default Re: Fuel line help
meant to put its got a D15b stock in the engine bay.
Old Mar 5, 2010 | 03:42 PM
Ldo's Avatar
Ldo
Did you use 2 wrenches and turn against each other?
Old Mar 5, 2010 | 03:50 PM
radex7's Avatar
^^^ Yup, that will do. One (open box wrench or vice grips) goes on the black hexagonal(?) nut like thing to keep the filter in place, the other one will undo the bung bolts. Good luck.
Old Mar 5, 2010 | 05:25 PM
yep tried that also thing still wont budge. i am going to go get a can of PB Blaster tomorrow hopefully that will help loosen the bolts.
Old Mar 6, 2010 | 12:57 PM
PB blaster still hasn't helped and I'm about to loose my patience lol I need HELP!
Old Mar 6, 2010 | 01:26 PM
Ldo's Avatar
Ldo
Damn dude, are you sure you're turning the right nuts in the right direction? Sounds to me like they're welded down or something.
Get somebody with a 21mm wrench to hold the lower nut on the filter, slide 3 ft pipe into your 17mm wrench and turn that bitch. If that doesn't work, I guess you have to just cut them up and get new lines from the junk yard.
Old Mar 6, 2010 | 02:56 PM
jayturboef's Avatar
^^^^^ do this and make sure the filter is not moving and takin up ur torque...
Old Mar 6, 2010 | 03:07 PM
Ya I need to grab someone to help I was literally using everything I got felt like my damn arm was gonna snap lol. Well Ill let u guys know how it goes any more ideas please let me know
Old Mar 7, 2010 | 02:09 PM
SUCCESS! lol, it took a minute of pounding with the impact wrench to get the 17mm bolt off and i had to take the line off the engine and unbolt the filter put it on a bench vice and wrenched the hell out of the oval bolt for a few minutes with a crows foot and breaker bar. damn thing probably wasnt changed since day 1, 20 years ago . But thanks for everyones help and ideas.
Old Mar 7, 2010 | 04:24 PM
Ldo's Avatar
Ldo
^^ congrats. I'm surprise you didn't set off a spark in the process
Old Mar 7, 2010 | 04:38 PM
radex7's Avatar
LOL, no kidding, he was definitely overheated himself.
EK9r!der
18
Aug 23, 2012 09:57 PM
civic_66
Mar 6, 2009 07:00 AM
Nicram
Feb 12, 2006 10:42 AM
MartinLude
Nov 9, 2004 03:36 PM
