ECU?
Old Mar 5, 2010 | 10:59 AM
supercharged d's Avatar
Default ECU?
is a p06 ecu able to run a d16a6 without a tune? need to know asap...if not what will. thanks
Old Mar 5, 2010 | 12:00 PM
LA_HONDAS's Avatar
Default Re: ECU?
youll be fine
Old Mar 5, 2010 | 12:23 PM
dpetro1's Avatar
Default Re: ECU?
more info is needed. do you have a conversion harness? are you running stock injectors? if so then you should be fine
Old Mar 5, 2010 | 12:34 PM
Default Re: ECU?
i have an obd0 to obd1 conversion harness....and stock d16 injectors...the motor is in a 91 wagon 2wd. 5 speed
Old Mar 6, 2010 | 04:20 PM
Default Re: ECU?
bump
98bucket
12
Oct 24, 2010 04:13 PM
ef dino
Sep 30, 2008 07:32 PM
cdndna
Feb 6, 2006 11:11 AM
EF4lyfe
16
Jun 15, 2004 04:21 AM
