b20 bottem end or gsr
Old Mar 5, 2010 | 09:15 AM
zaremba850's Avatar
Default b20 bottem end or gsr
what do yall recemend? im wanting to turbo with a worked b16a2 head
tork>< high rpms?
take into consideration im building the low end for boost 8.5-1 compression
Old Mar 5, 2010 | 01:17 PM
98civdx's Avatar
Master Detailer
Default Re: b20 bottem end or gsr
what the hell is tork?
i reccomend gsr, b20s have soft sleeves. and you say worked b16 head what do you have?
Old Mar 5, 2010 | 09:48 PM
thumper64's Avatar
How much power are you aiming for? Only planning to run a few pounds like 200hp or like 500? The amount of power you're aiming for will dictate what you need to do or if you could get away with the B20
Old Mar 5, 2010 | 09:51 PM
doritosFTW's Avatar
I believe Tork is a city in Norway? Maybe he is going for NDM But seriously I would go B20 and SLEEVE it
Old Mar 5, 2010 | 09:56 PM
iamthefollower's Avatar
I agree with thumper64, the amount of power you are aiming for will determine what everyone would choose from.
Old Mar 5, 2010 | 10:01 PM
spoon_concept_eg6's Avatar
GS-R, more durable, unless your rich that is.
Old Mar 6, 2010 | 01:21 AM
818ek9's Avatar
gsr better sleeves
Old Mar 6, 2010 | 05:40 AM
98y8's Avatar
B20 and just get it sleeved. But then again, it depends on how much power your looking for. Plus a B20b from the 96-98 CRV already had compression around 8:8 compression
Old Mar 6, 2010 | 05:51 AM
darkrell's Avatar
ill would go with 98y8 the b20 is what u need
Old Mar 6, 2010 | 10:01 AM
CDUB740's Avatar
New User
i would have to say b18c
Old Mar 6, 2010 | 10:04 AM
K20egcw's Avatar
Since you want boost, go with a B18 block. N/A go with a B20.
Old Mar 6, 2010 | 10:25 AM
newtron63h's Avatar
agreed.
you dont need more displacement with boost. but if you decide to stay N/A.........you need displacement.
Old Mar 8, 2010 | 04:30 AM
zaremba850's Avatar
excuse my spelling earlier i ment (torgue) its a b16a2 head and im wanting to get 300-350 whp and anywere from 15-20ish psi
Old Mar 8, 2010 | 06:51 AM
98y8's Avatar
If you want that much horsepower I suggest you build the bottom end, not use a stock bottom end. I would get the block sleeved and use forged rods and a nice set of low compression pistons.
Old Mar 8, 2010 | 10:41 AM
K20egcw's Avatar
You can get 350hp pretty easy with a stock build. There really isnt a need to build the bottom end until you get around the 500hp mark, thats about the limit for a stock block. The rod bolts are usually the weakest part of the bottom end, so if you want to change anything change those first.
Old Mar 8, 2010 | 10:49 AM
zaremba850's Avatar
i am gunna build the low end.
thanks for the info guys
Old Mar 8, 2010 | 11:06 AM
jdmcivicracer89's Avatar
still spelled it wrong haha its torque... id go with a b18
tundra2000
Dec 15, 2010 02:12 PM
jscrib
Sep 7, 2010 06:59 PM
2000EK9
Nov 14, 2006 12:25 PM
l3owen
Feb 7, 2004 11:13 AM
Passaudi1.8t
Jan 7, 2003 05:11 PM
