Heater issues continued
Old Mar 5, 2010 | 06:46 AM
ssssmashing's Avatar
Default Heater issues continued
Ok, so I posted on here a few days ago that my heater stopped working in my 99 Accord. So I checked the fuses and the relay and everything checked out fine. I purchased a new blower motor and installed it EUREKA! I've got heat again. 2 days later the heater starts acting up again and will only work when the fan is in the 4th (high setting).
So now what?!!!! From what I have read it would appear that the resistor has gone bad, but where is that and how do I replace it? The beauty with the motor is I was able to replace from under the dash without ripping the dash apart. Can I do something similar with the resistor?
Thanks in advance for your help!!!!!
Old Mar 5, 2010 | 07:37 AM
nus_dogg's Avatar
Default Re: Heater issues continued
Resistor is behind the glove box.
Resistor one and two is probably burned out.
Old Mar 5, 2010 | 07:40 AM
Thanks Dogg! Do you know anywhere where I can find how to do this online? I'm not sure what I'm looking for.
Old Mar 5, 2010 | 07:49 AM
Could I have done anything wrong to cause this? I mean it was working after I installed it. It was an aftermarket fan so I had to splice the wires, but I assume I did it correctly since it worked.
Old Mar 8, 2010 | 07:47 AM
I'm thinking I may just take it to the honda dealer.
jimi323
Aug 20, 2015 11:37 AM
usdmftw
Jan 28, 2013 08:18 PM
Bpost
Aug 15, 2010 06:08 PM
evolved
Jan 23, 2006 05:22 PM
servion
Sep 16, 2003 09:03 AM
