17" Enkei NT03 with khumo rubber
Old Sep 7, 2002 | 08:14 PM
Indecisive's Avatar
Default 17" Enkei NT03 with khumo rubber
I was hoping someone could help me out.
I found a nice set of Enkei 17" rims with khumo tires and am looking to pick them up very soon. With this setup, how much can I lower my 96 ex coupe without any possibility of rubbing?
Old Sep 7, 2002 | 08:49 PM
nwdave's Avatar
Default Re: 17" Enkei NT03 with khumo rubber (Indecisive)
It all depends on the offset. With the wrong offset, you could rub at stock height.
But usually, you can lower up to 2" without rubbing.
I'm lowered 2.25" on 16" wheels (with 45-series tires) with a +42mm offset and I don't rub, even on full-lock.
Old Sep 7, 2002 | 08:53 PM
Indecisive's Avatar
From the thread the guy had, there was a link to an online store that I think he got the rims from and they said +00 offset. Can that be right?
If so, what bearing will that have on my lowering ideas....
Old Sep 7, 2002 | 09:04 PM
nwdave's Avatar
+00?
I have no clue really about how specific offsets will work. I just know that it matters
Old Sep 7, 2002 | 09:40 PM
akeldama's Avatar
Default Re: 17" Enkei NT03 with khumo rubber (delsolguy)
I'm guessing that they are probably +40mm offset if the rim is 7" wide. If it is 7.5" wide then the offset is probably +45. The 7" w/ a 205/40/17 tire set-up you probably would be okay with a 1.8" or less of a drop. +42mm is the ideal offset (for a 7") but it's hard to find on 17" wheels.
sony224422
Sep 21, 2006 12:00 PM
Nathan007
Apr 18, 2006 10:56 AM
biff
Jan 13, 2004 01:12 PM
beaterman
Dec 27, 2003 07:20 PM
cokinut
Mar 30, 2003 04:03 PM
