K-Pro Vs. Haltech Ecu
Hal-Tech
K-Pro
In all fairness if i could do it all over again i would go Hal-Tech. Granted its about 1500 for it but its a stand alone ecu and you get to keep your stock ecu. Not only that it has some pretty nice features...
General Specs:
Direct plug and play replacement of the OEM ECU, no rewiring necessary.
Uses the cars factory sensors
Supports Sequential Injection (peak and hold) and Direct fire ignition
Windows 2000, XP, Vista compatible software
Real time programming, instant hesitation free adjustment while engine is running
Fully user definable 32 x 32 mapping
Tuning via Volumetric Efficiency (VE), Injection time or Lambda Correction (MAF)
Selectable onboard internal MAP sensor rated to 150kPa (up to 1.5 Bar or 22psi boost)
Wideband auto tuning using user definable target AFR table
USB and CAN Communication Port
Factory Outputs:
4 x Fuel Injector outputs
4 x Ignition outputs
Tacho, Boost Control, AC Clutch Relay, Idle Control
Thermo Fan, Check Engine Light, Fuel Pump (Variable Speed)
I-vtec Control, with simple user friendly mapping
Factory Inputs:
MAP sensors, Throttle Position Sensor, Oxygen sensors,
Coolant Temperature sensor, Vehicle Speed Sensor,
Air Temperature sensor.
Expansion I/O*:
2 x Analogue Voltage inputs
2 x Analogue Temperature inputs
4 x Digital pulsed outputs
*Optional auxiliary harness required to be purchased Haltech Part # HT040003
Functions:
Closed Loop O2 Control
Decel Cut Over Boost Rev Limiter
Knock sensing and Control
Closed & Open Loop Boost Control With Gear offsets (higher boost in Higher gears)
Gear Setup
Transient Throttle Enhance
Correction Tables: Fuel Ignition Boost:
Cranking
Air Temp Target Correction
Coolant Temperature Correction
Map Correction
Zero Throttle Gear Correction
Cylinder Trim
TPS Correction
Generic Correction 1
Generic Correction 2
Gear Correction
Post Start
Air Temp Duty Correction
Post Start
Miscellaneous:
Data Logging: 448Kb of onboard data logging, Storage for approx 40 minutes at 10 logs per seconds, 6 channels of data
Max 20 channels logging capability
Tune can be password protected in software
Rugged anodized aluminum casing
Power Requirements:
Source: 8.6 to 16.5 Volts DC
Consumption: 530mA @ 12Volts DC
Physical Dimensions:
ECU Dimensions Length: 154mm (174mm with MAP nipple)
Width: 158mm Height: 42mm Weight: 680g (1.5 lb)
Factory Outputs:
Factory Inputs:
Expansion I/O*:
Functions:
Gear Setup
Cranking
Map Correction
Cylinder Trim
TPS Correction
Gear Correction
Post Start
Post Start
Miscellaneous:
Power Requirements:
ECU Notes:
Base maps are included only for K20A2, K20A3 (RSX Base), K20A3 (Civic SI) and K20A engines.
- Support for the manual K20A3 engine and the secondary intake runner as used in the base model RSX and CRV.
- The Japanese PRD and PRC ECU do not support a fuel tank pressure sensor required for some US emissions tests, but will likely pass a tailpipe sniffer test if the catalytic converter is in place.
- PNF, PPA and PND ECUs for 5 speed transmissions will not operate the reverse lock solenoid on 6 speed transmissions.
- The K-Pro will not work on Automatic vehicles. Automatic ECUs cannot be converted to manual.
Features:
Mounts in stock location and plugs into stock wiring harness.
Retains full immobilizer functionality to protect your vehicle from theft.
High speed USB connection
Re-calibrate for larger injectors.
3 dimensional tables for full i-VTEC mapping.
Compatible with OBDII diagnostic tools & smog station scan tools.
Datalogging of 40 major sensors.
User programmable fuel, ignition & cam angle tables.
Control of open / closed loop operation.
VTEC window control.
Multiple fuel & ignition tables for different intake cam angles.
Expanded tables for up to 11 lbs boost (even more with a 3-bar MAP sensor).
Nitrous control with activation window control, solenoid output control and fuel/ignition parameters.
Features:
Hal-Tech is on CRSX so you can ask them yourself hahaha or just hit up CRSX themselves and ask them but i would recommend going straight to the source since they are on CRSX...
Right now, they have made it for teh 05-06 RSX as a plug and play (not sure why exactly) but they do offer the harness to convert it down to be plugged into the earlier models EP3/RSX
I have both a Platinum plug and play box and the Sport 2000 Box that will be going on my race car for the year...just working out a couple other bugs before the switch.
I just became a Haltech dealer after seeing their fabulous new software at PRI this year...the LOGGING is why I am exciting about it. In combo with a nice Racepak dash (which I have as well) there is NOTHING you cant log, play back and get exceptional data with at the track.
If anyone is interested in the new plug and play boxes, we are a long time Honda-Tech vendor
I am currently rocking the R&D ECU on my 2004 EP3
but yes.. If you cannot wait, there is a boomslang harness you can use to make the DC5 ECU work.
did you have any experience with the haltech E8 to make a comparison to the new ecu's (sport series)? im assuming that is what you are referring to, the new software that comes along with the new ecu's.
http://www2.haltech.com.au/index.php...=156&Itemid=49
i'd say go with what you can find some one to tune. i mean i think the aem ems would be a good option as would say an ems singer. but we have people that tune just about anything down here in south fl.
tech23
10
Feb 11, 2010 07:40 AM
Carbcivic
11
Oct 11, 2007 05:45 PM
KStuned
Nov 27, 2006 01:18 PM
