2000 si Overheating ISSUE HELP ASAP!!!
Ok buddy has a 2000 si and its still overheating after replacing waterpump and thermostat. Fan still works and holds collant untill it overheats then it comes out of the overflow tank anyone have any idea what could be the prob?
compression leaking into the coolant jacket, therefore over-pressurizing the cooling system, triggering the rad cap, which in turn will make it regurgitate coolant indefinitely through the overflow...
A blown head gasket is a real possibility. But first replace the radiator cap and bleed the cooling system. During the bleeding procedure, regularly check whether the lower radiator hose remains cool even after the engine is hot. If so, the radiator may be clogged.
I'm thinking the radiator could be clogged, check the cap and bleed the cooling system as everyone has stated and check all that before having to pull the head off.
if the ride aint puffing a white smoke screen, spend 100 bucks and buy a aluminum radiator of ebay or something. that radiator is probably clogged. check spark plugs, they shouldn't be burning white, or be wet. common trouble shoot for these problems, black smoke=burning rich(gas), white smoke=burning water, gray=burning oil. end of story.
accel
Apr 10, 2013 07:54 PM
runwitme
14
May 17, 2009 04:16 PM
Seye
Nov 5, 2003 07:25 PM
