Replacing Amber Bulbs On My EG6 SiR Cluster HELP!
Old Mar 4, 2010 | 06:00 PM
EusebioSam19's Avatar
Default Replacing Amber Bulbs On My EG6 SiR Cluster HELP!
my clusters bulbs seem to be out
and i cant find a DIY on how to fix it.
can some one point me in the right direction?
Old Mar 4, 2010 | 06:11 PM
Kyoh's Avatar
Default Re: Replacing Amber Bulbs On My EG6 SiR Cluster HELP!
Take off your cluster benzel first. You'll have to take the clock off to get the benzel off. After that there is a couple mounting screws for the cluster. Take those off. Then unplug the cluster. Once you have it out, there are these little round connectors on the back that just turn and come out. Take out the three bigger ones and the bulb will be in the connector. If all the bulbs went out at once, then check your fuses under the dash first.
Old Mar 4, 2010 | 06:47 PM
does anyone know the size of the bulbs
someone told me that the ek ones have like condoms or somethin over
the bulb making it amber
aghhh i wanna see my cluster at night help
Old Mar 4, 2010 | 07:20 PM
Kyoh's Avatar
All the oem blulbs are white with like blue condoms on them making them whiter. Just get these bulbs. Can find em at autozone or anywhere.
Old Mar 4, 2010 | 07:43 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Wait a minute -- all your bulbs are out? If they all went bad at the same time, you have a different problem than just burnt out bulbs. It might be a fuse, it might be a bad ground ... but probably not all burnt out at once.
Old Mar 4, 2010 | 07:45 PM
Kyoh's Avatar
^^That's what I said.
Old Mar 4, 2010 | 09:13 PM
eros18's Avatar
x2
also
Search:
Keyword(s): DIY cluster lights
Forum: Honda Civic/Del Sol (1992 - 2000)
Search took 0.16 seconds
all info on how to remove cluster, change bulbs, where to buy the bulbs are all there.
creizlein
Lighting
Jul 6, 2016 10:31 AM
egvtec
Feb 10, 2008 12:06 PM
1uncleanDA
Apr 26, 2006 06:08 PM
The G2 Racer
Jul 18, 2004 04:38 PM
