92 civic dash problems
Old Mar 4, 2010 | 04:23 PM
torinored eh9's Avatar
Default 92 civic dash problems
just bought a 92 civic hatch with a ls swap! and the signal lights do not work or the dash! nothing on the dash works what could it be? i was thinking its making ground somewhere!!
Old Mar 4, 2010 | 05:05 PM
Former User's Avatar
Default Re: 92 civic dash problems
Do the hazard lights works? Do the cluster gauges work? Do the cluster lights work? Do the heater control panel buttons work? All don't work?
delsolproblems's Avatar
If the entire cluster is not working, including the gauges, start by removing it and checking the connectors on the back.
Old Mar 4, 2010 | 08:30 PM
idk about the hazard! but yeah the cluster is not working lights or gauges!! the plugs on the back are fine !!
Old Mar 4, 2010 | 08:36 PM
10A fuse 15 under the dash is almost surely blown.
Old Mar 4, 2010 | 09:09 PM
okay cool i will try that tomorrow morning!!
Old Mar 5, 2010 | 10:28 PM
ok i turned it on today and the ac and heater control panel buttons work and some of the lights form the cluster like the battery !
Old Mar 5, 2010 | 11:02 PM
jasoncanseeoh's Avatar
torinored, chill with the effin exclamation marks.
But, will they just light up or are they not working in general?
If they aren't lighting up, your dimmer switch may be the problemo.
Old Mar 5, 2010 | 11:30 PM
gauges are not working and just the battery light and some other light light up! my blinkers do not work ether.
Old Mar 6, 2010 | 09:06 AM
dang !!! i put the fuse and that is what it was bro!! thanks!!
Old Mar 6, 2010 | 09:38 AM
nice.
Old Mar 6, 2010 | 09:53 AM
yeah it didn't even have that fuse. i think its missing a lot, there is a bunch of slots empty
Old Mar 6, 2010 | 02:27 PM
okay everything is working except the speed and temperature gauges!!
Old Mar 6, 2010 | 02:33 PM
pocketkiriyama's Avatar
New User
LOL yeah sometimes simple things are missed. I had a friend with a ek9 hatch that just can't seem to get one of his headlights to work. He tried getting some help from a few of his friends. Finally he came to me as I was working on my eg6. I found that the ground for the headlight (aftermarket btw) was loose. So tightening it did the trick.
Old Mar 6, 2010 | 05:06 PM
Is CEL code 17 thrown?
Also check the 1-wire temp sending unit under the distributor.
Old Mar 9, 2010 | 04:38 PM
its throwing codes but idk witch ones!!
717DC
28
May 9, 2014 06:21 PM
thorgerd
10
Feb 2, 2012 09:42 PM
99civicsi19
Nov 21, 2010 07:57 AM
Xathine
19
Feb 4, 2009 04:27 PM
nolen
May 26, 2007 11:44 AM
