question regarding thermostat
Old Mar 4, 2010 | 04:17 PM
austinkli's Avatar
Default question regarding thermostat
Well I am already fairly certain that I need a new thermostat. So I'm just wondering if this could also cause another issue.
When it's exceptionally cold out it takes my car FOREVER to warm up, and even then once I hit about 50mph the temp gauge goes right back down and the motor cools and stays below optimal operating temp.
Could a bad thermostat cause that?
Old Mar 4, 2010 | 04:21 PM
D Griff's Avatar
Default Re: question regarding thermostat
Definitely. They're cheap and easy to install and I'm pretty sure that's your problem.
Old Mar 4, 2010 | 04:23 PM
austinkli's Avatar
Ok thanks. I know how easy it is, and pretty cheap, just wondering if that's my issue.
I also have no heat so I'm pretty sure that I need a new thermostat.
Old Mar 4, 2010 | 04:26 PM
D Griff's Avatar
I'm 99% sure that's your problem.
Old Mar 4, 2010 | 04:29 PM
BryanM.'s Avatar
Resident Gearhead
You almost certainly need a new thermostat. Remember to bleed the air out of the system as well.
Old Mar 5, 2010 | 04:48 AM
Matt93eg's Avatar
X2, and remember to put the little bleed hole that's on the actual T-Stat at the 12 O' Clock position when you install it.
Old Mar 5, 2010 | 06:14 AM
dpetro1's Avatar
more specifically, a t-stat stuck open would cause that. if it were failed in the closed position you would be overheating with a quickness.
replace it with an OEM honda piece and you will be all set
Old Mar 5, 2010 | 06:22 AM
turbodcxbro's Avatar
I'm having the same issue but already have replaced the T-stat with a new OEM unit as well as the radiator, fan and all hoses!! My car barely heats up to about 1/4 of the gauge and when I coast down a hill it goes back to cold!
did you have normal heat before? did your gauge stay around 1/2 way when warm?
superninja
Honda Civic (2001 - 2005)
10
Dec 23, 2021 05:05 PM
ej6kid
Jan 26, 2013 08:42 AM
bumthology
11
Dec 11, 2004 11:23 AM
iH8RICERZ
Feb 3, 2004 12:59 PM
Gen5lude
May 10, 2003 12:41 AM
