Flashing CEL light
Old Mar 4, 2010 | 02:29 PM
newyawkballa's Avatar
Default Flashing CEL light
I saw this "99 Civic Ex for sale.The car is an automatic.When the car started up,the check engine light was on.The car was running for over 5 minutes,and then i noticed the check engine light flashing.I owned in the past,a 96 Civic,98 Prelude Sh,and a 96 Integra and none of the CEL's flashed while the car was running.The seller is only asking $1200.The body needs paint and is 3 colors and thieves stole the climate control and the radio.I know this question is kinda bird like,but any help would be great.Thanx...
Old Mar 4, 2010 | 03:51 PM
Former User's Avatar
Default Re: Flashing CEL light
A blinking CEL indicates engine misfiring severe enough to damage the cat.
Old Mar 4, 2010 | 06:57 PM
canadaek's Avatar
run away
Old Mar 4, 2010 | 07:23 PM
HAMOTORSPORTS's Avatar
This is right.. On OBD2 vehicles, the ecu 'knows' when the engine is running badly enough to cause major damage (ie: misfire) However, this could be as simple as a tune-up
Old Mar 4, 2010 | 08:02 PM
forcefedferio's Avatar
The flashing check engine light is indeed a catalyst damaging misfire, and would probably be accompanied by a p0300 random misfire code at the very least. It could be any number of things, ranging from the previously mentioned tune up stuff (plugs/wires/cap/rotor/fuel filter) or could be a bad o2 sensor and is just dumping fuel (just happened to my girlfriends EM1 2 weeks ago).
Unless you are prepared to spend some coin, i would stay away.
Old Mar 5, 2010 | 12:13 PM
Thanks a lot guys.I'll stay away...
Rupinder Summan
Jul 10, 2014 02:47 PM
HondaAllDay
Apr 6, 2009 09:56 AM
CaliRockrr
Nov 26, 2005 04:37 PM
98teg
Oct 6, 2003 07:39 PM
