new to hondas...already stumped
Old Mar 4, 2010 | 02:02 PM
SatanicMechanic's Avatar
Default new to hondas...already stumped
Ok, so first off, hello I'm dallas. Enough of that, lol
I purchased a 1991 honda crx DX (5spd d15b2 dpi). I was told the fuel pump was bad, read around, found that main relays are main problem. Pulled relay, tried a few things i found on honda-tech by Ahknod, didnt seem to work for me. I have power at #1 pin and ground at 2. I jumped the 5 to 7 and now fuel pump. Checked for voltage at pump with relay in..6v. checked for voltage while jumping 5 to 7...6v. Hooked a KNOWN good pump to the 6v source...nothing. So im thinking ok maybe the pump isnt turning because it's only getting 6v. But WHY? I bypassed the relay so that isnt the issue on the 6v issue. Im guessing its 5 and 7 (from akhnods post at https://honda-tech.com/forums/showth...35047)....Does anyone know why I'd be getting 6v? I checked every fuse i found under the dash and under the hood. #14 was bad, replaced it..but just 6v. I checked my ground on thermostat housing as ive read those tend to go bad. Now, the #1 terminal on the harness side has 12v....12.02 actually...but 6v at pump with or without relay.
Another issue is not cranking at all. Almost like a dead starter...but I am thinking it could be a ground considering the lack of V at the pump. Where will I find my other main grounds. I know its on the trans somewhere, but cant seem to find it...this car has been sitting for 3 years and has spider webs/wasps nests all in the engine bay and thousands of fire ants (which have been ELIMINATED MUAHAHHA) under the driver seat. Battery is BRAND new...just got it like 2 hours ago. Looking for any and all sugggestions. If any of you guys live in Tampa/Lakeland area and wanna come over and take a look let me know. Ill take any help I can get.
Also, on the no crank, I notice when I turn the key ALL the dash light stay on, dont really dim much but I hear a CLICK coming from what sounds like the center of the dash (behind the radio area). Is there a relay back there that could be bad?
Thanks guys!
Dallas
Old Mar 4, 2010 | 03:16 PM
lunalink's Avatar
Default Re: new to hondas...already stumped
Old Mar 4, 2010 | 07:09 PM
crx-si's Avatar
Jump the starter out to see if you have a bad starter just use i piece of wire from the power to the signal terminal on the starter, and the grounds are on the transmission, valve cover, and thermostat housing.
SpoonEk253
41
Oct 3, 2022 03:21 PM
BTaylor
May 29, 2022 03:35 AM
jun10r27
Dec 13, 2009 09:16 AM
jlfrnce
Dec 10, 2009 05:48 PM
mr_hahn73
15
Oct 21, 2007 10:17 PM
