Need help witha misfiring LS engine
Well you keep cranking until you get the highest reading. 3 things cause misfire comp, spark, fuel. You can get the two wires with light bulb and plug it in the 1st cyl injector clip and see if its flashes. I think your comp is good. Its prob spark.
if it flashes its getting a signal, its good there. Check if you have a right firing order. I heard before that cat might cause it, but i never had that prob so i dont know the symptoms.
Maroonda9
Jun 26, 2005 08:47 AM
