what injectors to use?
Old Sep 7, 2002 | 07:10 PM
bluedelsol's Avatar
Default what injectors to use?
what injectors should i use in my d15, any injectors from other motors that i should use?
Old Sep 8, 2002 | 12:33 AM
tinkerbell's Avatar
Default Re: what injectors to use? (bluedelsol)
the answer to this question is 'use the injectors that came with that engine.'
t..
Old Sep 8, 2002 | 03:36 AM
bluedelsol's Avatar
Default Re: what injectors to use? (tinkerbell)
what if i put a new fuel rail on and a new fuel pump and pressure ragulator and boost my fuel pressure? then will i need bigger injectors?
Old Sep 8, 2002 | 03:42 AM
MikeSarr_GSR's Avatar
if you want to wash the cylinder linings with fuel and lose compression, sure
go right on ahead unless you have an ECU that can clock back the injectors
and lean em out if you put in larger ones, you will lose like 20% to the wheels.
not my idea at a fun day at the dynometer
Old Sep 8, 2002 | 03:45 AM
bluedelsol's Avatar
Default Re: what injectors to use? (MikeSarr_GSR)
ok, that answered my question, thanks
afnan
Jan 15, 2014 11:00 AM
I Like Hondas
May 30, 2008 02:11 PM
B_1_8_hatch
Sep 12, 2003 11:23 AM
VaporTrail
Feb 11, 2002 09:23 PM
