Honda accord 97 transmission slip. HELP!!!
Hi , a week ago my honda accord 97 with only 74,000 miles start to slip a little on second gear and alot on third gear. yesterday i put transmission conditioner and it fixed the problem and it stopped slipping. Today when i woke up it start to do the same thing again. Any ideas? what i can do from here?
What kind of conditioner? Was it from Honda?
Anything but Honda ATF fluid is not a good thing for your transmission.
Much like older British cars must use Castrol Brake Fluid(not Dot 3), Honda Automatics must use Honda ATF Z-1. The automatics made by Honda are closer in relationship to a manual transmission than a rotm automatic.
Why on earth did you put a transmission conditioner in there?
Drain that transmission immediately and put brand new OEM Honda ATF purchased at a Honda Parts Counter at a dealership.
And do that 3 times (search on procedure)
http://www.autozone.com/autozone/cat...Name=Lucas+Oil . this is what i put in
I'm quite skeptical you actually did that. *Maybe* you did but you'd be a god with teleportation.
And I should stress very much - the ATF you buy at Advanced Auto is NOT NOT NOT NOT NOT what you should use, regardless of what they tell you or your mechanic told you.
Use ONLY HONDA ATF!!! If it doesn't come in a grey Bottle with HONDA in a header at the top, don't buy it. Yes Honda ATF is expensive, but so is rebuilding an AT. Some of the wording found on other ATF brand bottles may hint at being compatible with Honda ATF, its not. Only use Honda ATF.
