Suspension & Brakes Theory, alignment, spring rates....
which hole to mount swaybar in...Function 7
Old Mar 3, 2010 | 09:30 PM
2000EJ8's Avatar
Default which hole to mount swaybar in...Function 7
Car- 2000 Civic EX
LCA's- Function 7
Swaybar- 22mm CTR
there are 4 holes on the LCAs.....three in a straight line, and one below those....is the correct mounting hole the one that is below the other 3?
Old Mar 3, 2010 | 10:47 PM
frogsplash's Avatar
Default Re: which hole to mount swaybar in...Function 7
The three holes are where you mount it. Each one, I believe starting from the frame going to the tire is, soft, medium, hard. Basically it increases or decreases the strength of the bar using basic geometery without having to fully swap out different MM bars. Say your bar is 22mm, bolting to the middle hole will have the affect of a 22mm bar, where as going to the inboard hole will theoretically give the affect of a smaller MM bar, and going to the outboard hole will in-turn do the opposite of the inboard hole. Now how much of an increase or decrease, if from what I have read is right, I am not sure.
Old Mar 4, 2010 | 07:10 AM
2000EJ8's Avatar
ive heard that before as well, but as of now my endlinks arent as perpendicular as i think they should be.....thats why im curious to see if they stock mounting location is the bottom hole, with the other 3 being if you want to fine tune your bar
Old Mar 4, 2010 | 07:34 AM
frogsplash's Avatar
That is why they make adjustable endlinks, and that bottom hole, I am pretty sure is not for mounting the sway bar. I know the SK2's dont have a bottom hole just three top ones if compared to yours.
Old Mar 4, 2010 | 08:16 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The hole below the other three IS the correct mounting hole for a 96-00 Civic using OE end links. The OE arms have the sway bar end link hole in that location, in the middle of the arm.
The other 3 holes require the use of adjustable end links.
Old Mar 4, 2010 | 08:45 AM
GagnarTheUnruly's Avatar
^^ what he said. Integras use the upper holes, Civics use lower holes. OP -- just use whatever hole lets your endlink be straight and your sway bar be horizontal (should be the lower hole).
Old Mar 4, 2010 | 01:14 PM
2000EJ8's Avatar
i have Function 7 Adjustable endlinks.....is the bottom hole still the correct mounting location, or is that only a location for stock endlinks such as SI links?
Old Mar 4, 2010 | 01:37 PM
Community Builder
huh? The OP's F7 arms are for 96-00 Civics only. Integras and 92-95 Civics have their own LCA design, which uses a hole towards the top edge (the F7 versions have 3 near the top).
Old Mar 4, 2010 | 03:19 PM
1.5Slowmatic's Avatar
F7 commented on this a little while ago. I beleive it goes like 5%-10%-15% stiffer on the holes in that order from outside to in and the bottom hole is OE location
Old Mar 4, 2010 | 04:24 PM
I was intending to correct confusion but I don't think I did a good job. I thought that frogsplash was thinking of the Integra and earlier Civics that correctly mount on the top with the factory endlink. On the later Civics the endlink mounts into the center of the arm. Someone used to hearing that on Integras and some Civics the central mounting point is wrong (e.g. with Blox) might not realize that it's correct for control arms designed for 96-00 Civics.
Old Mar 4, 2010 | 07:17 PM
frogsplash's Avatar
Sorry, didnt read it was a '00 civic ex. Was thinking about my integra.
vectorsolid
40
Aug 5, 2011 01:08 PM
bedheadben
Suspension & Brakes
14
Oct 4, 2009 07:51 PM
h22 civic
Apr 20, 2007 02:59 AM
117
Suspension & Brakes
Apr 21, 2005 01:06 PM
Lo-Buck EF
Oct 22, 2002 02:31 PM
