Keep blowing fuses need help asap!
My car is a91 ef hatch base model and the brake lights and gauge cluster lights don't work. I replaced the fuses four times and it blows immediatly. I'm guessing there is a short but I don't know what to do about it. I unplugged the battery terminal to put on the power wire to my sub and tightens everything back to normal. If any one has any advice let me know thanks.
Chances are you have water in one of your bulbs.
Start by replacing all the lamp bulbs first.
I had the same problem in my wagon, and it was a soaked bulb socket.
there this tool that looks like an ice pick with a light inside call a circuit tester. It will check if the wire has power to it and therefore if it is grounded
looks like that
looks like that
I have this same problem in my 91 DX.... all lights work except brake ligts...
keeps blowing the 10 amp fuze under the hood .... also knows as the horn fuse...
any tips?
already replaced the brake light bulbs and i even have put 30 amp fuse in...
still blows em
any tips?
still blows em
black-91-si
Mar 30, 2011 06:50 PM
EcivicG
11
Jun 23, 2008 03:40 PM
rhd_ej coupe
Feb 1, 2008 09:56 AM
slikz714
Jun 1, 2006 06:46 PM
