Bumper removal
I have a few questions about bumper removal for my 90 rex. When i bought the car it came with a bodykit
, and said bodykit while not too ricey is molded in
. I recently bought a half size radiator to suit my turbo setup, do i have to remove the bumper to remove the radiator, and i also would like to know (i know you must remove the bumper for an intercooler) would i be able to remove the fenders and bumper at the same time to take it all off? or are there bolts holding the fenders on under the bumper? Please help
if you just poped the hood and looked you would see that you dont need to remove the bumper to pull the radiator. as far as pulling the whole front as a clip im sure you could get it all unbolted but once you try taking it off i bet it would crack where its molded.
idc if it cracks, ill just sand it down to the original and just touch up where i sanded it, and while im in the process ill pry get a stock bumper and make a good youtube video of the burning of the rice
If you are going to take the front end off you need to unbolt the the fenders and the bumper seperate. There's a bracket that connects from your fenders to your bumper but most likely it's going to bend or brake if you don't seperate them first.
so there is no way to take off the bumper and fenders at the same time, can i cut the bumper and fender apart so i can take the bumper off? (sry but the car is at home and i go to college 3 hr away so i cant look at it right now)
