Del Sol power windows
the power windows in my del sol aint workin, i think its the fuse in the switch in the door panel thats no good, but can i take that out of any civic with power windows or does it have to be from another del sol?
think it has to be from a del sol .. since the fitment is different.
Are you sure it's the switch ? Take an ohm-meter and test it. If it's good, hook up a tester to your battery and connect terminals in the connector to see if the windows work then. There's a lot of places to find a manual for that to figure out which terminal controls which window.
I've had the same problem with my sol and it turned out that the cables were all messed up where they enter the door .. corroded and broken etc ..
Do you hear a clicking sound when u move the switch from underneath the radio ? ( that's where the main power window relay is located )
thanks man! its not the main relay cuz the rear window still goes down, and theres clicking, at least thats what the guy i bought it from said, wont hurt to try it myself, thanks again
96civic808
Dec 20, 2015 03:27 AM
martin4o2005
Jun 16, 2011 01:48 PM
