Iac block-off plate
Are you really getting rid of it just for the sake of getting rid of it? I dont have an IACV on my car and at times it has a rough time idling. By the way, all stock TBs have an idle screw and we still run an IACV...your idea just doesn't seem to add up
OMG!! Why does everyone on here need a reason to answer a question! If you know what Im looking for just tell me! Since you have to know, I have an Edelbrock 70mm tb on my VictorX manifold. The TB completely blocks off the iac so it's not needed. The iac on there now is leaking vacuum so I wanna take the thing off! Btw my car idles fine without it so you may need a better tuner!
I highly doubt the iac is causing the leak. More then likely it could be a small tear or pin hole in the hose or dirt between the o rings and manifold. Could be any reason that there is a leak. TB to manifold, manifold to head. There really is no need to take it off whether your car now needs it or not. Most cars i know still have them due to the sensor and most cars tuned or factory idle like crap once its unhooked. But since your so set on saving that couple ounces why not take it off and lay it on a piece of aluminum or steel, trace it and cut to make your own. Just my $.02
I pressure tested the system and it's leaking from the iac. It's dissabled and unplugged. All it's on there for is to block the hole off. And the iac is hitting my brake lines too, so if there is a plate it's only reasonable to get that. I may try to cut one now that you said that.
IntegraType-R
19
Nov 12, 2007 08:39 PM
crxsiperf
Aug 12, 2006 11:43 AM
LudeHatchH22a
Mar 9, 2004 06:24 AM
