audio issues
Old Mar 3, 2010 | 10:04 AM
91akira's Avatar
Default audio issues
I have a kenwood cd Head unit along with a second cd player.
Top HU is a KDC-716s
Bottom is a KDC-D300
Problem:
With the Head unit in operation, I get sound with all four interior speakers along with the sub. But when I remotely switch to the bottom cd player to play music (KDC-D300), only the two right side interior speakers along with sub work and not the two left side speakers.
I removed both HUs to see what the wires look like in the back. It appears it has two wire harnesses. One to the HU and one to the cd player. Nothin seems to be loose. The system plus wiring was done at Professional shop ....10 plus years ago. BUT not the interior speakers and head units. As I changed those several times.
I have nothing major. Just a simple set up.
Head units stated above.
two JL audio fronts
two JbL back
350 watt amp bridged.
Any help is appreciated.
Old Mar 8, 2010 | 07:24 AM
91akira's Avatar
Default Re: audio issues
55 replies? Thanks
Old Mar 8, 2010 | 07:52 AM
mrdeadman's Avatar
They let me pick
Why do you have two hus? The top one has a cd player (unless it is broken) and the bottom one is only a cd player.
The relays for the cd player's speakers are probably fried. have you externally amped the speakers?
Old Mar 8, 2010 | 10:09 AM
91akira's Avatar
No they run throught the HU. the sub is the one thats amped.
I run two head units because I like to switch off from cd to cd. Kinda like a cd changer. And Kenwood aloud it to work that way.
Old Mar 8, 2010 | 12:44 PM
mrdeadman's Avatar
They let me pick
The relays that allow the switching for the outputs of one hu to the speakers to the other are probably fried.
Old Mar 9, 2010 | 07:08 PM
01gokartlx's Avatar
The other HU should be connected to the main HU via the auxiliary cable. That way you can hit the source button to switch from "CD" to "AUX". Is this how you have it hooked up? If not, then you should.
Old Mar 10, 2010 | 09:47 AM
91akira's Avatar
Yes it is hooked up that way.
shifts
Oct 11, 2014 08:39 AM
DCFerris
Audio / Security / Video
Apr 13, 2009 06:54 PM
dylokjai
Mar 22, 2005 02:01 PM
bisket
Nov 13, 2003 10:41 PM
drsues02
Jun 7, 2002 09:54 PM
