window and locks need an electrician lol
Ok so I'm still haveing problems with my right rear window the switch is working and also at the master but the other windows work fine.
What can I test to figure out what does'nt and does work?
I'm going to test and jump the motor to see if that is it. Fuses are fine I've checked and double checked.
Now the power locks how can I test the lock module and the switch I'm going to jump the actuator and test that first.
I really would appreciate anything as I'm stumped and not an eclectical genius. Thanks Adam
Take off the door panels, make sure that you dont have anything unplugged at the window switch. If everything is plugged in, wires/fuses/relays good, then you have a bad motor.
is there a relay for just one window and just the locks? and yes i had them off more than a few times, so i tested the motor and the lock actuator both of them worked fine when hooked up to a jump pack with jumper wires. the window switch works on other doors. so i think i may be a wireing issue. any thought on that or how to fix/trouble shoot??
Trace the wire all the way back to wherever it leads to. I've never had to diagnose a window switch problem, but treat it the same way as you would do any other wire tracing.
Im still certain that the motor/actuator is jacked up, rather than fuses/wiring.
Ok but I jumped the both of them the window went up an down when hooked up to a 12v jump pack I havent had the window move in months so I know that's fine. As for the lock aviator I was able to jump that too and get it to lock and unlock that door. My buddy went to class this morning and went and asked his shop teacher about it. He thinks by the symptoms and motor/actuator working when jumped that it's a broken wire for the window or locks. Or still the lock module possible. Were going to rip more apart tonight and take a closer look. I'll get back with what we find out! Thanks by the way man
Ok we checked voltage at the window switch and 12 shows up. Put the switch on and it Worked!!!!! Holy crap right? Ya put it back on the door and I didn't work at all, took it back off and nothing. So were going to take the door off one day. As fo the lock there wasn't 12v to it or the lock module so when we do the door were going t o check at the fuse and then down the wires.
_Bug_
Audio / Security / Video
Sep 7, 2006 02:46 PM
