B20/Vtec guys please chim in...
Old Mar 3, 2010 | 06:38 AM
sho_shane's Avatar
Default B20/Vtec guys please chim in...
I have a B20/Vtec in my car. Its blowing smoke and oil from the breather hole on the valve cover. The Bottom end is a 96 or newer B20 so there is no pcv vent in block. What are you guys doing for a PCV systems on your B20/Vtecs?
Old Mar 3, 2010 | 08:46 AM
Top Ramen's Avatar
You should try searching - there are a BUNCH of threads on this. Try "PCV" and "breather" or "catch can."
Old Mar 3, 2010 | 01:44 PM
sho_shane's Avatar
Default Re: B20/Vtec guys please chim in...
Thank you for your helpful post. I have searched it and im still unsure on what to do. All im asking is for people with a B20/Vtec to please post up the way they have there systems.
Old Mar 3, 2010 | 04:00 PM
negusjuda's Avatar
get either the endyne or z10 breather kit im gonna use the z10 kit
Old Mar 4, 2010 | 09:57 AM
sho_shane's Avatar
ttt guys looking for some input.
The z10 breather kit looks like its made to be used with the Port on the back of the motor. Since my bottom end it a 96 and newer that port is not there.
Old Mar 4, 2010 | 10:12 AM
red_crx's Avatar
Heres a few different catch can/ vented valve cover setups:
https://honda-tech.com/forums/welding-fabrication-53/vented-valve-cover-post-up-some-pics-1970101/
What are the specs on the b20/vtec? Is it just a stock b20 block with a stock Vtec head...etc
Old Mar 4, 2010 | 11:23 AM
sho_shane's Avatar
https://honda-tech.com/forums/showthread.php?t=1970101
Yes that is all it is. Its running on a P28. I was told that just one day it started blowing this smoke out the valve cover.
Old Mar 4, 2010 | 11:57 AM
red_crx's Avatar
I'd start by doing a compression test before doing a catch can setup
Old Mar 4, 2010 | 12:00 PM
sho_shane's Avatar
Ya but im afriad to...
Old Mar 4, 2010 | 12:12 PM
sho_shane's Avatar
I dont own a Leak down tester. I dont know anyone that does, Would a Comp test not help me figer it out?
Old Mar 4, 2010 | 12:20 PM
kulo's Avatar
will a cusco catch can be ok for b20v setup
Old Mar 4, 2010 | 03:21 PM
BigDare23's Avatar
Here is a little write up I did when I was venting the valve cover on my b20vtec. Hopefully it helps you out with part numbers if you decide to vent your valve cover.
http://eastcoastefcivics.com/index.php?topic=1050.0
Also, I'm using a catch can from these guys.
http://www.carolinahondas.com/blueri...240sx-s14.html
Old Mar 4, 2010 | 03:49 PM
negusjuda's Avatar
my bottom end is a 99 the z10 kit and the endyne kit hooks up where the 2 freeze plugs on the back of the block are its those 2 big plugs you cant miss them they come out and are replaced by the 2 plugs that come with the kit
Old Mar 4, 2010 | 08:27 PM
spuddo01's Avatar
ttt
Old Mar 4, 2010 | 10:50 PM
.Manny.'s Avatar
Touching My Member
I need to do a better job of venting my engine as well
Old Mar 4, 2010 | 11:09 PM
akandok's Avatar
i vented the block.. this way
https://honda-tech.com/forums/showpo...36&postcount=4
Old Mar 5, 2010 | 02:28 AM
negusjuda's Avatar
Originally Posted by akandok
yea thats the same way endyne and z10 kits are same plugs
Old Mar 5, 2010 | 03:57 AM
sho_shane's Avatar
Did A Comp Test last night and its no good. Heres how they look:
1-100psi
2-180psi
3-180psi
4-40psi
Again there is no smoke out the rear of the car so what do you guys think?
Old Mar 5, 2010 | 04:31 AM
negusjuda's Avatar
with that kinda compression what else can it be besides rings unless valve seals can cause a compression drop either way motor needs to be rebuilt or atleast the head does if its valve seals
Old Mar 5, 2010 | 06:03 AM
red_crx's Avatar
1-100psi
2-180psi
3-180psi
4-40psi
Damn
Old Mar 5, 2010 | 06:32 AM
sho_shane's Avatar
I was thinking that number 4 might be a bent valve. That would also explain the ton of blowby.
Old Mar 5, 2010 | 06:33 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
your ring didn't seal, or cracked ringland will cause a low compression, plus smoke coming out of holes it shouldn't be coming out of
Old Mar 5, 2010 | 07:42 AM
sho_shane's Avatar
Well the cars been sitting for 3-4 months. Do you think driving it around for a bit might seal the rings up? If thats what it is.
Old Mar 5, 2010 | 07:44 AM
i doubt it, once your start a fresh motor and the rings don't seal then you basically have to re do everything.
Old Mar 5, 2010 | 07:58 AM
sho_shane's Avatar
This motor is not fresh? Its a older motor I think. I got it from a guy, Its been sitting for 3-4 months when I got it. I just got it running again.
