oil catch can installation on b20 vtec
Old Feb 25, 2009 | 09:02 PM
calishowa's Avatar
Default oil catch can installation on b20 vtec
do i have to drill a hole next to the knock sensor on the b20 block to install the oil catch can or is there another way.. i've seem picture where they just drill on the valve cover need help..... can't find any good post online
Old Feb 25, 2009 | 10:02 PM
DRtools's Avatar
Default Re: oil catch can installation on b20 vtec
http://www.c-speedracing.com/howto/c...n/catchcan.php
Old Feb 26, 2009 | 09:35 AM
94eg!'s Avatar
#1 Super Guy
Loved
There is two large plugs on the back side of the block. There are fittings and seal-washers you can buy that replace those plugs. This will proide with two hose fittings to connect the block to the catch can. Then from the can you an either vent to atmosphere (illegal) or run a third line to the PCV valve and into the manifold... Here's a pic of the components...
BTW: I would not want steel-wool rusting up inside of the catch can. Especially if you have a drainback installed. I've heard of using that plastic materal from a shower scrubby. That sounds better IMO...
Old Feb 26, 2009 | 10:49 AM
IT GUY's Avatar
Old Mar 2, 2009 | 03:51 PM
SDyang's Avatar
what about the valve cover, i've seem some where there runinng two holes from that to the catch can
Old Mar 2, 2009 | 07:09 PM
94eg!'s Avatar
#1 Super Guy
Loved
Great pic IT Guy! That really shows what's what...
SDyang, people usually mod the valve cover to run a second catch can. No sense drilling, welding and plumbing your valve cover unless really NEED the block to breath. At that point it should be a race car (not street), so there's no problem venting to atmosphere...
Old Mar 13, 2009 | 05:12 PM
chillz03's Avatar
http://cgi.ebay.ca/GReddy-TRADITONAL...1%7C240%3A1318
so it i get this geddy kit and the two fitting this will work for me keeping in mind i dont have a stock oil beather chamber ?
Old Apr 6, 2009 | 10:18 PM
allmotorlsbaby's Avatar
So the two fittings on the back of the block that you can order are they only for the b20 block?
Old Apr 8, 2009 | 10:25 PM
chillz03's Avatar
no i got them for my b18
Old Apr 9, 2009 | 06:57 AM
unusual71's Avatar
I notice everyone always seems to run 2 of these fittings, wouldnt running one be sufficient for mild set ups?
Old May 28, 2009 | 07:01 AM
gettin it's Avatar
Where did you purchase the 2 fittings from? Did you get them from honda? If so, do you have a part number please?
Old May 28, 2009 | 12:36 PM
Natural Aspirations's Avatar
Are you seriously ****ing blind?
Old May 28, 2009 | 06:01 PM
gettin it's Avatar
Sorry, couldn't see the pics at work. I was on Gov't cpu. But thanks guys.
Old May 28, 2009 | 10:17 PM
bluenc-87's Avatar
Dumb questions!!!! There are 2 fittings on the side of the catch can does it matter where these two hose connect to the block and which way to connect the pcv valve because it goes on 1 way only right????
Old Jun 5, 2009 | 05:44 AM
gettin it's Avatar
Ok just installed my moroso catch can and 1 line from the back of the block, was getting tuned last night and oil started coming out the can. We had to drain it 3 or 4 times. Is this normal? Or do i need a drain back?
Old Jun 5, 2009 | 05:53 AM
FST GSR 1's Avatar
Welcome to block venting...Too bad you got steered the wrong way in this thread.
Old Jun 5, 2009 | 06:47 AM
killerpenguin21's Avatar
can you explain?
ive been waiting to put my block ports in since im burning a little oil, and only have a valve cover breather right now.
Old Jun 5, 2009 | 09:42 AM
FST GSR 1's Avatar
When you only use the block fittings for the vent, the crank case pressure will get behind volumes of oil on acc/dec's and push it into the can. If you don't have a drain back it will fill up and over flow quickly.
I drain my can once a year and it has very little in it. This is also a can setup that vents to the atmosphere though.
Old Jun 5, 2009 | 10:28 AM
how are you running your drain back?
Old Jun 6, 2009 | 12:37 PM
gettin it's Avatar
Ok so what is the proper way for the install? Or should i just drain it on the ground from the bottom of the can?
Old Jun 8, 2009 | 03:19 AM
gettin it's Avatar
Bump
Old Jun 8, 2009 | 05:01 AM
FST GSR 1's Avatar
I don't need one.
Old Jun 8, 2009 | 06:52 AM
gettin it's Avatar
So your letting it run out on the ground? Are your hoses connected to the back of the block?
Old Jun 8, 2009 | 07:05 AM
FST GSR 1's Avatar
WTF are you talking about? Look at the picture...2 -12AN from the VC to the catch can which is a moroso can I modified. The can comes with a drain valve if you wish. I removed it and just put a plug in the bottom, I remove, drain and clean the can once a year before I put the car away. Draining back the oil and moisture would be the last thing I would want going back into my motor.
Old Jun 8, 2009 | 07:13 AM
yeah i realized my mistake...at first i wasnt sure if that was your car, now that i see you only have a VC vent i know why you dont need a drain back.
