H22a swap to Honda Accord 96 EX
Hi i have a H22A engine swap going on. I'm looking for someone who has a full scamatic of my year and model. I have a Honda Accord 96 EX. Also, I need to know were I can find the fuel pump power wire under the dash and at the ECU. I used my stock F22B1 engine harness and I got the motor to turn over but no fuel is running through the line. Also, I have the full H22A engine harness but it was cut at the firewall portion connecting to the ECU. I can solder it back together but my ABS is on an independant harness and the H is on the same as the engine harness. So if I use the H harness how would I connect the harnesses together?
FYI- It was not a plug and go so I would like to find a wire diagram that way I can depin and repin to make it a plug and go.
Murph
Murph
tkhang
Aug 31, 2010 03:14 PM
