Some questions on turbo size for my application.....
Fully built ZC motor.
Going to run about 25-28psi....around 400HP.
I'm thinking a .70 AR T4 compressor + .60 AR T3 turbine.
How do you think this turbo will spool?
How does it compare with a T3 60-1?
what do you think?
what do you think?
Oh....one more question....
Do you think its possible for say....Majestic to do a BB option for the turbo?
I will email Them later on, but am just wondering if anyone has had close hand experience.
thanks
Bryson
thanks
Bryson
Bump the A/R on the exhaust side up to .63 and you have the same A/R specs as the standard 60-1 (.70 A/R intake, .63 A/R exhaust). For 400whp, the 60-1 is a good choice. Mine spools at 4k on a stock LS motor.
cool...
what psi do you max out at?...and what RPM?
Is the 4000 where the turbo starts to pull hard?...or where the turbo actually starts to create boost?
Thanks for being the only valid response so far!
