WTF?! Why is my ED6 spitting up gas??
Old Mar 2, 2010 | 01:17 PM
-dSoc- soccerwuedo5's Avatar
Default WTF?! Why is my ED6 spitting up gas??
Smells like gas in the car. Gas seeps out a bit at a time since I bought it (on the outside AND inside of the fuel door). I am stumped. Check the pics and help me out!!
Gas leaks out here
Looks like this up close
Also seems to leak out here
Up close (the problem??)
And ruin this little guy
Which all together looks like this
Lifted the other end of the filler neck (under the aluminum cover)
These don't look too bad, do they?
So any help that you guys can offer would be amazing!!! Thanks so much!!!
--Jake
Old Mar 2, 2010 | 01:35 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: WTF?! Why is my ED6 spitting up gas??
I would replace the three nuts that are missing {6mm X 1.0 mm}
as there is a rubber gasket on the back of the filler neck..
That should keep it out of the car..
The arrow on the right..Is there a small dent there?
It could be as simple as the gas cap not sealing...
It should be able to hold pressure..
Check the gasket inside the gas cap also..
Old Mar 2, 2010 | 02:11 PM
The three nuts I just removed today while working on it! Lol! As I hosted the pic I thought to myself, "Someone is definitely gonna tell me I'm missing some nuts"
As for the gasket, that is in place and looks fine. I don't see any tears, stretching or even discoloration.
And the dent...you may be right. I would have to get a whole new filler neck just to fix that one little dent, wouldn't I?
Thanks for your reply (with the picture!)
Old Mar 2, 2010 | 05:09 PM
ED9man's Avatar
get a new gas cap, the rubber is probably hard from being so old and doesnt properly seal anymore, caps are cheap and in stock at pretty much any parts store. whats happening is the gas sloshes up the neck against the cap when you take a hard right and then is leaking out.
Old Mar 3, 2010 | 08:33 AM
I'll check that today, for sure!
So, it sounds like you're saying that this spillage only happens when hard turning is involved, correct?
Old Mar 3, 2010 | 11:28 AM
D16SiHatch's Avatar
maybe your evap lines back from the tank are blocked. which would allow for a buildup of pressure. with my old hatch i had let it sit idling in the street for a few minutes once, and when i came back later a fair amount of gas ended up on the road. i was like uhh wtf lol. it came right up through the fill neck.
Old Mar 5, 2010 | 11:22 AM
Alright Ill check that for sure!
So far I've got to check
.gas cap
.gasket on the back of the filler neck
.vent
.evap lines
Anything else? Ill be able to start tackling this tomorrow AM (college life this week has been on the busy side )
Thanks for all your help!
tunedX
Jan 22, 2018 10:49 AM
circapunk
12
Dec 13, 2008 12:19 PM
kemo909
Apr 30, 2007 06:01 PM
big purps
Jun 11, 2003 03:23 PM
SpoonPL
Jul 11, 2002 06:52 PM
