Fatty coolant leak
i have a pretty big leak of coolant idk where its coming from or how it happened last night it was driving perfect no leaks now i went to go start it up let it idle for lik 10mins drove then parked n seen a leak
please help!!
please help!!
From: I told you to wait in the truck in Texas, United States
Easiest way to find a coolant leak is with a
"cooling system pressure tester.."
You can probably borrow one from an auto supply
if they have a loan a tool program or maybe a radiator shop..
Make sure to get the adapter to fit the radiator also..
X2 your other choice is to top up coolant then run car at idle and see if you can see where the leak is coming from but the pressure tester is the best way to go.
juevi
14
Aug 21, 2011 01:34 PM
SeanK325
Jun 22, 2010 02:52 PM
