Suspension & Brakes Theory, alignment, spring rates....
Brake Fluids
Old Mar 2, 2010 | 10:09 AM
dingobat's Avatar
Default Brake Fluids
Hi all,
I just changed my front brakes on my Civic 96 lx sedan. I leaked some fluids and now my brake paddle isn't like it use to be anymore. It's a lot deeper. How do i refil it?
Old Mar 2, 2010 | 10:27 AM
roastbeefrichie's Avatar
Default Re: Brake Fluids
anytime you break the bolt on the brake hose/caliper or brake hardlines, you introduce air into the brake system. air in your brake lines usually results in spongy pedal feel
since you stated that you leaked brake fluid, there is most likely air in your system. get a bottle of brake fuid and bled the brakes. don't let the m/c go dry & keep it filled
Originally Posted by BrakeExpert
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
Floren
Honda Civic (2006 - 2015)
Jun 25, 2018 07:18 PM
mshields4129
Jun 18, 2011 06:18 PM
jdm-ek-si
Suspension & Brakes
Aug 31, 2007 07:04 AM
mengy007
Honda Civic (2001 - 2005)
May 27, 2006 10:53 AM
viperguy
Jul 29, 2003 06:57 PM
