grinding
I have the same issue, but my always grinds when I put it in 5th gear. From what I learned, the syncromesh ring is worn out.
To the OP, trying changing the transmission fluid with Synchromesh MT Fluid which may temporally fix your issue, or all together. Your local Autozone should have some Pennzoil Synchromesh fluid and costs about $15 for 2 quarts.
I had the same issue with 4th gear in my 90 integra. It'll be cheaper if you can take out the transmission yourself and take it in to a shop. I paid 200 but I had them replace the main shaft bearing as well while they had it open.
