grinding
Old Mar 2, 2010 | 05:39 AM
chr0nz's Avatar
Default grinding
i noticed that when shifting to 5th gear it grinds sometimes and sometimes it doesn't what could be the problem?
Old Mar 2, 2010 | 05:59 AM
Visionaire's Avatar
Default Re: grinding
i'm having the same issue but with third also...
Old Mar 2, 2010 | 06:16 AM
Apathy47's Avatar
I have the same issue, but my always grinds when I put it in 5th gear. From what I learned, the syncromesh ring is worn out.
To the OP, trying changing the transmission fluid with Synchromesh MT Fluid which may temporally fix your issue, or all together. Your local Autozone should have some Pennzoil Synchromesh fluid and costs about $15 for 2 quarts.
Old Mar 2, 2010 | 06:36 AM
Alex M.'s Avatar
Same here, except mine is third gear, especially at higher RPM's.
Old Mar 2, 2010 | 07:01 AM
senser1080's Avatar
Yeah mine grinds third at high RPMs too.
Old Mar 2, 2010 | 08:19 AM
abusedvtec's Avatar
mine grinds going into 3rd at 7k +
Old Mar 2, 2010 | 08:20 AM
abusedvtec's Avatar
its deff not clutch or flywheel prob just did those and it still does it
Old Mar 2, 2010 | 08:23 AM
eatsleephonda90's Avatar
lol 90% of my friends say 3rd gear is da first one to go out on hondas
Old Mar 2, 2010 | 08:46 AM
abusedvtec's Avatar
its because everyone is tearin @$$ into third
Old Mar 2, 2010 | 11:44 AM
chr0nz's Avatar
how much does it cost to get it fixed?
Old Mar 2, 2010 | 11:49 AM
HondaPartsHero's Avatar
Technical Hero
I had the same issue with 4th gear in my 90 integra. It'll be cheaper if you can take out the transmission yourself and take it in to a shop. I paid 200 but I had them replace the main shaft bearing as well while they had it open.
Old Mar 2, 2010 | 03:08 PM
Apathy47's Avatar
read my post above. It doesn't sound too serious right now. Synchromesh fluid should be a good solution, for now anyways.
jimmyrab
May 17, 2008 05:43 PM
defkid999
Jan 24, 2006 02:02 PM
nemesisSI
13
Apr 11, 2005 01:09 PM
elevatethis
41
Nov 24, 2003 12:02 AM
Young_R
Dec 13, 2002 06:30 PM
