Suspension & Brakes Theory, alignment, spring rates....
Koni + GC = Bottom Out?
Old Mar 1, 2010 | 09:48 PM
surrealx's Avatar
Default Koni + GC = Bottom Out?
Hello
I drive a 94 DB that is completely stock
I purchased brand new koni yellows sp3 and a set of mint condition ground controls for koni.
I'm not too sure why I keep bottoming out in the front? I have OTS spring rates for dc.
Can anyone help me out here?
Old Mar 1, 2010 | 09:52 PM
STOCK_SOHC_DX's Avatar
Default Re: Koni + GC = Bottom Out?
Springs too low?
Old Mar 1, 2010 | 09:55 PM
surrealx's Avatar
I have the perch at the first setting which is the highest one.
Old Mar 1, 2010 | 09:58 PM
But is your perch near the bottom? Also is your Fronts the stiffer of the two springs?
Old Mar 1, 2010 | 09:59 PM
surrealx's Avatar
The perch is near the top, highest setting not the lowest. The stiffer rates are in the front, correct.
Old Mar 1, 2010 | 10:00 PM
Maybe you need stiffer rates.
Old Mar 1, 2010 | 10:03 PM
surrealx's Avatar
Maybe but is this normal for koni/gc? I mean every single little pot hole sounds horrible..and sometimes when going over a uneven paved road somewhat like a wavy road, It would sound as if its already bottoming out.
Old Mar 1, 2010 | 10:38 PM
surrealx's Avatar
Any help/advice will be greatly appreciated. This is horrible :'(
Old Mar 2, 2010 | 02:13 AM
Meoshe's Avatar
Sounding like its bottoming and acutally bottoming out is different. Is the sleeve and the perch both at the highest setting? If so that's only about a .5" drop there is no way you should be bottoming out.
Old Mar 2, 2010 | 02:22 AM
kristo's Avatar
Loved
A picture of the coilover would help.
Try reading the markings on the spring, to know springrate.
Old Mar 2, 2010 | 04:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Is the GC SPRING PERCH near the top or bottom? You could just be too low for that spring rate.
I hope you're referring to the Koni circlip being on the highest setting. You should NOT use the Koni spring perch at all with Koni-specific GC sleeves.
Old Mar 2, 2010 | 05:03 AM
meb58's Avatar
What are the exact rates AND length of the spring? Every rate ahs a length that is appropriate...or not. You may well have enough damper travel, but if the spring's rate or length is not correct the spring will reach block height before the damper and bump stop do. This will result in a very nasty crashing sound.
Remove the springs and install the dampers. Then, measure the full suspension stroke - you will need to identify the damper's piston postion at ride height first. Get under the car - on an alignment rack - and tie a zip tie to the pistion. When you perform your travel experiment you will know where bound and rebound begin and end. Then calculate this dimension agsint the spring's block height - can be found on GC's website or Ground Control's web site. If you have progressive rate springs I cannot help you.
If your car is lowered by 1" - 1.5" the front rates should be in the ~ 350lb/in range. I am unfamiliar with a 94 DB, but if it has an SLA front end your ride height and camber will change the motion ratio. So you need to be aware of what that will mean for a ~350lb/in spring.
Old Mar 2, 2010 | 09:06 AM
kristo's Avatar
Loved
Pictures, pictures, ...
Old Mar 3, 2010 | 09:57 AM
91h22cb7lx's Avatar
x43 on pictures
and if the car is lowered did you cut the bumpstops?
im still confused how you have this all adjusted
also if you can post the part numbers of your springs
kevinm1981
Suspension & Brakes
18
Jul 10, 2010 02:05 PM
thanh4o8
Suspension & Brakes
Aug 15, 2009 11:33 AM
Jar-Head23
Suspension & Brakes
Jun 28, 2009 11:15 AM
tEhNgUyeN
Suspension & Brakes
16
Aug 27, 2005 03:27 AM
Myh4tch
21
Jan 20, 2004 04:15 AM
