fully built gsr Dart long block 85mm cp pistons 9.1 crower rods
Old Mar 1, 2010 | 09:22 PM
construct1's Avatar
Default fully built gsr Dart long block 85mm cp pistons 9.1 crower rods
SOLD, SOLD, SOLD THE MOTOR TODAY.
$5500 firm longblock, 3500 for the shortblock, 2000 head, i'll take 4500 for longblock minus dizzy,intake,fuel rail,oil pan,valve cover,vtec line. i'll put a stock pan on and valve cover for that. fully built dart longblock 0 miles on the shortblock.
i have all the recipts of the machine work as well as all the new parts that are on it.
looking to sell as a longblock with everything on it the way it is in the pics, but will sell shortblock,or head
all you need are injectors, your flywheel, clutch, tranny and it's ready to drop in a car
i'm not looking for any trades or to part anything, so no trades i'll trade for cash in my hand
i'm in no hurry to sell it, will put it in a car if i don't get what i want
all the assemble work was done by tony at aes machine shop, he built all of stephanie eggums motors.
dart b18c block not the tall deck just a regular gsr block, 85 mm darton sleeves closed deck, dart blocks you can replace one sleeve at a time if something screws up, pretty sure none of the other sleeved blocks can you do this, my other erl block i have for sale you can't replace just one sleeve.
all new:
cp pistons 9.1 85mm
crower turbo rods
micropolished gsr crank
cleavite bearings
moroso 5.5 quart oil pan alum, pickup, pan studs, pan gasket
oil pump
water pump
tensionor
belt
arp head studs
head gasket
rear seal
fluidampr crank pulley
vtec oil line to head
i'll do 3500 for the shortblock everything included in the pics, including oil pan, vtec oil line. you pay shipping
head is a gsr endyn mild port and polish, bought it used with 4-5k combustion chambers are at 84.5mm, all three rocker arms are clearanced for high lift cams.
skunk2 +.5 intake valves, stock size exhaust, bronze guides endyn, these are the only used on the head. head was cleaned and reassembled
the rest i list is new:
skunk2 springs and pro series retainers
seals
blox p1 cams skunk2 pro1 copies, identical specs
crower cam gears
edelbrock victor x intake manifold
hondata gasket
msd pro series dizzy, coil, harness
golden eagle fuel rail
moroso valve cover, gasket
i'll do 2000 for the head with everything in the pics on it, might have more wiggle room on it if i sell the shortblock.
here's the money shots:
Old Mar 1, 2010 | 09:25 PM
construct1's Avatar
Default Re: fully built gsr Dart long block 85mm cp pistons 9.1 crower rods
here's some more pics
Old Mar 2, 2010 | 04:01 AM
Myroslav69's Avatar
Thats sooooooo SEXY!!!!!
Old Mar 2, 2010 | 07:18 AM
endless_pain's Avatar
Wow, just wow.
Old Mar 3, 2010 | 09:21 AM
construct1's Avatar
thanks for the bumps guys, went through what i have in it 7,522 the way it sits now, so i'm losing 2g
Old Mar 3, 2010 | 09:47 AM
JDMInteg96's Avatar
bump it up.. super clean
Old Mar 3, 2010 | 11:14 AM
construct1's Avatar
just posted prices for the shortblock and head seperate. i tried to get pics of the head but they put it on the block before i could get pics of the combustion chambers and valves. i do have the build sheet from endyn from the guy i bought the head from. i added new stuff on the head anyway,cams, seals, springs retainers, etc... and my machine shop clearanced the rockers, valve adjust, and put all that stuff on it.
Old Mar 4, 2010 | 11:00 AM
construct1's Avatar
ttt
Old Mar 5, 2010 | 09:34 AM
construct1's Avatar
bump
construct1
Mar 5, 2010 09:18 AM
boostedb18c
Jan 16, 2005 06:10 PM
sloweg6
Mar 30, 2004 04:54 PM
