help with hasport axle
Old Mar 1, 2010 | 07:39 PM
CRX_RR's Avatar
Default help with hasport axle
there is a clunking noise when i turn left on the passenger side axle. axle are new. got them 1 years ago, it did this to when i first install them. i thought is was the tie rods and just last week i fixed the tie rods and its still clunking.
this is what i have. itr hydro tranny. new wheel bearing, new lower ball joint, new inner and outer tie rod, new upper control arm, and new caliper.
Old Mar 2, 2010 | 01:20 PM
CRX_RR's Avatar
Default Re: help with hasport axle
if it is my axle. anybody have a clue which axle i should get for the passenger side? i'll be using the stock crx si knuckle.
Old Mar 2, 2010 | 02:24 PM
EJ1_Sleeper's Avatar
sure its not the rack end bushing? (mine is toast and clunks)
Old Mar 2, 2010 | 02:27 PM
sh!ft's Avatar
Who the fack changed my title?!
so wait, your axle is new but you have had it for a year? im confusors
Old Mar 2, 2010 | 04:36 PM
lvmevo's Avatar
man, kinda confusing, not a honda but my evo broke axles at the track one night. so i replaced them with good axles. still had clunking noise. turned out to be my transfercase. on in your case the lsd gears. put the car on jacks 2nd gear and listen for the clunk or watch to make sure both wheels are turning at the same speed. good luck
Old Mar 2, 2010 | 04:50 PM
CRX_RR's Avatar
yeah i put them in a year ago but never drove the car. but like i was saying, when i first install them in. they were making a clunking noise when i turn left. maybe i've just gotten a bad axle, idk. other then that i change all those things, and it still clunking. And before the engine swap this had never happened. the clunking noise
luciffer
Nov 15, 2008 11:43 AM
duefuss
13
Oct 21, 2008 09:30 AM
SoFresh
Feb 15, 2008 09:43 PM
whatcivic
Sep 17, 2007 10:47 AM
nusdogg
Jul 31, 2005 04:03 AM
