DOHC ZC Tranny compatible with?
Old Mar 1, 2010 | 06:36 PM
BrayzieEF9's Avatar
Default DOHC ZC Tranny compatible with?
what motors can the DOHC ZC tranny bolt onto with no problem??
Old Mar 1, 2010 | 07:37 PM
eklum's Avatar
Default Re: DOHC ZC Tranny compatible with?
well since the dohc motor is compatable with sohc trannys one would have to think they are the same bolt holes/ dowels
Old Mar 1, 2010 | 07:58 PM
BrayzieEF9's Avatar
thx i wasn't 100% sure
Old Mar 1, 2010 | 08:32 PM
crx(gator)'s Avatar
and you thought wrong...
only compatible with the d16a6.
Old Mar 2, 2010 | 02:06 PM
hailchristian's Avatar
No. Could not be more wrong.
First of, its the ZC transmission, so of course its going to bolt up to Sohc zc and Dohc zc. Then you have all the other 4th gen civic transmission that are the same. D15b1, d15b2, d16a6, bla bla bla
All 1.6 and 1.5 tranny's will work on 1.5 and 1.6 blocks Zc trannys will work on engines that can support the necessary mid-shaft.
http://www.d-series.org/forums/trans...i-d-s-etc.html
Just make sure you have a way to install the bracket for the halfshaft on the ZC and your golden
Old Mar 2, 2010 | 04:22 PM
crx(gator)'s Avatar
yeah, and the d16a6 is the only d-series block besides the ZC that has the holes tapped to accept the halfshaft bracket due to the engine being used in the wagovan 4wd.
here is a link
http://hondaswap.com/civic-crx-ef/tranny-help-92519/
next time, do some research before you open your mouth.
devonb456
May 5, 2010 10:35 PM
stemiched
Nov 15, 2006 12:20 PM
ninjapanda
Nov 30, 2005 03:16 PM
Koyoloeor
Aug 9, 2005 04:19 AM
down_the_hatch
22
Nov 4, 2004 06:55 AM
