Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Wheel noob with ?'s
Old Mar 1, 2010 | 04:44 PM
JapnseDomsticMkt's Avatar
Default Wheel noob with ?'s
im looking into buying a set of wheels for my '06 civic si.
im a total noob when it comes to wheels and i need to know about offset. The wheels i want come in +40 and +35 offset. I have no clue what offset even is or what ones to order. maybe someone can lend me some advice on this subject or post pics of the difference thanks in adavance everyone.
Old Mar 1, 2010 | 04:57 PM
ajpturbopittsburgh's Avatar
Default Re: Wheel noob with ?'s
http://www.rims-n-tires.com/rt_specs.jsp
This is the best calculator I have seen. You just punch in what you have and what you want to get and it breaks it down for you.
Old Mar 1, 2010 | 07:06 PM
i-VTEC_DOHC's Avatar
+35 is flush.
Old Mar 1, 2010 | 08:41 PM
K5^'s Avatar
K5^
Brand New
Originally Posted by i-VTEC_DOHC
+35 is flush.
On what wheel?
Old Mar 2, 2010 | 05:58 AM
the wheel i want to get is the konig countersteer. (no comments on it being a knock-off) so still what is offset? with +35 will the rim be flush with the fender? BTW im rolling with the skunk 2 lowering springs if that makes any difference
Old Mar 2, 2010 | 06:06 AM
K5^'s Avatar
K5^
Brand New
Offset is the measurement of the distance of the back of the mounting hub to the centerline of the wheel. If you go to the tire/rim calculator that AJP posted, you will notice the measurement that says offset. It measures the back of the hub to the cross hairs (with respect to the vertical hashed line) that mark the centerline.
A 0 mm offset would indicate the hub right at the centerline, while a +30 mm offset would yield a hub spaced 30 mm outward or away from the car. Inversely, a -30 mm offset would give you a hub that is 30 mm passed centerline, i.e. toward the car.
Old Mar 2, 2010 | 06:22 AM
thanks k5! now the real ? is do i go with the +35 or +40 for my civic? maybe pics of both if anyone has them
Old Mar 2, 2010 | 06:25 AM
K5^'s Avatar
K5^
Brand New
Go with +35 mm. A 5 mm difference is hardly noticeable, therefore I'd go with a minimum of 10 mm difference.
Old Mar 2, 2010 | 06:30 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
I think we'll need a small wheel thread too.
What's the general range of offsets that people are using safely on these cars?
Old Mar 2, 2010 | 06:31 AM
K5^'s Avatar
K5^
Brand New
Some will go as far as +20. But 'safely' I'd go with +30 to + 55.
Old Mar 2, 2010 | 09:48 AM
csmiths98AV6's Avatar
what is the width of the wheel
Old Mar 2, 2010 | 10:03 AM
Ross's Avatar
25 Year Member
Community Builder
How wide can you go on an Si without having to make other mods?
7.5", 8"?
Old Mar 2, 2010 | 10:23 AM
the konigs i want to buy are 7". anyone know the stock si wheel specs are?
Old Mar 2, 2010 | 10:30 AM
K5^'s Avatar
K5^
Brand New
OEM: 17 x 7 +45 mm.
Old Mar 2, 2010 | 11:14 AM
so why would i not go with the +40? im still pretty confused im looking to get them flush to the fender so +35 or +40?
Old Mar 2, 2010 | 04:28 PM
to be more flush your gonna have to run like an 8.5 +35 or so.
Old Mar 2, 2010 | 04:32 PM
Originally Posted by K5^
On what wheel?
on an 8.5.
i agree. im on +30 on an 8.5 and i need my fenders rolled.
Drew17th
14
Sep 24, 2008 04:56 PM
hinds90
Apr 22, 2007 11:05 AM
HamiltonRex
Oct 12, 2005 11:56 AM
torqueless
Jul 13, 2005 12:12 PM
JoeyBallzSI
Oct 20, 2003 03:04 PM
