How to replacement thermostat w/o a full colant flush...?
Old Mar 1, 2010 | 03:23 PM
A-dub5513's Avatar
Default How to replacement thermostat w/o a full colant flush...?
Hi all,
It has come to my attention that I may need to replace a thermostat that's stuck open. From what I've read so far, it's a relatively simple task, and can be done without a fully flushing the coolant. However, after a long search session, I can't seem to find a write up for this procedure.
Can anyone tell me how to go about the t-stat change if I don't want to flush the whole sytem?
Thanks,
Adrian
Old Mar 1, 2010 | 03:37 PM
nebraskaimport's Avatar
Default Re: How to replacement thermostat w/o a full colant flush...?
what year and car?
Old Mar 1, 2010 | 03:46 PM
A-dub5513's Avatar
I have a '99 GS-R...should have it on my sig at the bottom of my post.
Old Mar 1, 2010 | 04:01 PM
Apathy47's Avatar
http://www.team-integra.net/sections...?ArticleID=222
you'll lose some fluid once the thermostat is taken off, not sure how much. I think the coolant in the head is loss...somebody correct me if I'm wrong.
Old Mar 1, 2010 | 04:27 PM
mouab18c1's Avatar
Just take the thermostat out and put the new one in. Open your radiator cap and fill it to the top. Start the car and let air bubbles shoot out if there happens to be any. Do this for about 15-20 minutes or until your temp gauge is back to normal then close the radiator cap. You will have to bleed the coolant system no water what. Air bubbles will get into your coolant system once there is a leak or in your case spill out.
KHowe
Jul 21, 2008 11:02 AM
EB90RS
Feb 12, 2008 08:21 PM
bitr364
Jul 22, 2003 02:03 PM
migs
Dec 20, 2002 06:14 PM
