What bolts to use on a d16a6 on an engine stand?
Old Mar 1, 2010 | 12:07 PM
PopoCh3n's Avatar
Default What bolts to use on a d16a6 on an engine stand?
As the title says, What bolts to use? Any help is appreciated. Please and thank you.
Old Mar 1, 2010 | 12:08 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: What bolts to use on a d16a6 on an engine stand?
Tranny bolts since that's where the engine will attach to the stand.
Old Mar 1, 2010 | 12:15 PM
Radim's Avatar
Find out what size the trans bolts are, then go to your local harware store and buy some that are an inch or two longer, Measure before you buy!
Old Mar 2, 2010 | 04:59 AM
Sikocivic's Avatar
On my engine stand I needed shorter ones.
Old Mar 2, 2010 | 06:14 AM
JOE BD-0's Avatar
You can use washers to take up some space on the bolt. Good Luck.
Old Mar 2, 2010 | 08:30 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
I believe the size you are looking for is 12mm X 1.25mm
As far as length,
Measure how wide the holder on the stand is and
and add at least 1.25 to 1.50 inches..
You can also use longer bolts and short spacers
to move the engine a little further out
so you have room to mess with the flywheel etc..
Old Mar 2, 2010 | 04:37 PM
PopoCh3n's Avatar
Very nice. Thanks for all the help.
owa
Feb 3, 2010 05:18 AM
Anthrax-VX
Apr 24, 2004 05:43 PM
CovertFI
Jun 9, 2002 09:31 AM
B96v6
May 31, 2002 05:25 PM
