93' won't start. No Spark.
I am working on a friends 93' LX, When I first got my hands on the car I was not getting fuel. Checked Relay and it is good, Replaced Pump, Problem Fixed. Now I am getting fuel but no spark (I know unlikely that no fuel and no spark happens at the same time, only when you see this car is it possible) Any way I am not getting spark and I am throwing code 15, Ignition Output Signal.
I had the Ignition Control Module tested at autozone and it passed. Installed new plugs, wires, dist cap, and rotor. I am getting Voltage on 2/4 wire to the ICM, I have a continuity between the ECU and ICM via Ylw/Grn wire. My Coil is external. I also had a bad oil leak and replaced valve cover gastkets upper and lower seals.
I guess the only thing i have left to check is coil and distributor. Any help is appreciated
have you tried here:
http://techauto.tripod.com/
troubleshoots step by step any fuel or ignition issues
i have a 92 ex and i had the same problem the tps is located within the distrubitor and it had metled. so i had to replace the distrubitor and it solved my problem.
tinavagurly
Dec 10, 2017 06:57 PM
DabzMaGee
Feb 28, 2017 04:09 PM
