RS Machine sleeved LS block with girdle
This block was only ran for a few thousand miles and i have decided to part my car out
This is a 93 ls block that was sleeved by RS machines here in so cal. Sleeves are darton iron sleeves. The block is at 84mm and the walls look like brand new. This will also come with the z10 block girdle ls crank and main caps. ARP main studs and arp head studs. A GSR oil pan, windage tray and oil pickup is also included. ITR water pump, oil pump, timing belp are also all included and everything only has 2k miles. This LS block was also machined to fit the stock gsr/itr oil cooler which is also included with the gsr/itr water pipe. All sensors have 2 K miles and are also included.
just add pistons/rods and go race.
I want $1200 picked up
i'm located in downtown los angeles/echo park
