Camber kit solutions
Old Feb 28, 2010 | 07:05 PM
96F22B1Accord's Avatar
Default Camber kit solutions
What camber kits has everyone had experiences with and what do you recommend? Looking so far at megan racing kits (good price but maybe cheap parts?), SPC I've heard good things about but @110+ bux a side for the rear, a little pricey, and obviously Ingalls has always been a well known good/reliable brand but once again 120-140 a side front/rear.
Any suggestions or comments and experiences anyone has had are greatly appreciated.
Old Feb 28, 2010 | 07:28 PM
mark2583's Avatar
Default Re: Camber kit solutions
You'll be better off leaving the stock bushings in there. Camber kits, whether it be anchor or adjustable ball joint usually cause knocking on the fender due to less travel room and their bushings eventually start to squeak. A better alternative for saving your tires is to get an alignment every 3 months and ensure that they set your toe to 0(that is what kills your tires).
Another more unconventional alternative is to locate a shop that is familar with adjusting camber by bending the spindle. This gives you the adjustability of a camber kit without actually having one. In my opinion camber kits are unnecessary high maintenance parts.
Old Feb 28, 2010 | 07:36 PM
Well I'm only lowered about 2"s all the way around on GC coilovers, which use eibach pro kit springs (350 lbs front, 280 lbs rear), and Koni red shocks. My tires aren't wearing that bad at all honestly, slight camber wear but still fairly even tire wear across the whole tire (20k miles out of my last set cuz I'm very hard on my tires). I just want the adjustability and need to replace all my suspension pieces anyway (114k miles all original).
Old Feb 28, 2010 | 07:54 PM
19Accord97's Avatar
I've got Ingalls ball joints in the front and Wicked Tuning in the rear.
The fronts only hit the inner fender on medium size bumps.
Old Feb 28, 2010 | 07:56 PM
How much are you lowered though? And on what?
Old Mar 1, 2010 | 11:21 AM
19Accord97's Avatar
2.5 inches on Ground Controls w/ Tokico Illumina struts
Old Mar 2, 2010 | 05:34 AM
billyaccord96's Avatar
i have OBX camber screws with ES control arm bushing they both are not install yet
Old Mar 2, 2010 | 03:08 PM
02 accord's Avatar
I got the adjustable upper arms from Ingalls. They don't hit, no matter how big the bumps. But then again, I am on the negative side of adjustment.
Old Mar 2, 2010 | 03:18 PM
TheMuffinMan's Avatar
He knows where you live!
Well you can't just say that.
They have 2 different kinds. The ones that are up to correcting 1.5 degrees and the ones from 1.5 degrees to 3.0 degrees.
I had the 1.5-3 degrees correction and anything more than ~1.7ish degrees the upper control arm would wack the wheel well.
It has been found that the EF control arms will fit, so you can use an adjustable Skunk2 one. (don't quote me on the EF, but it's an older Honda)
Old Mar 2, 2010 | 03:19 PM
And for the rear just do the washer trick, I updated the FAQ with up to date pictures when I did it on my car.
Old Mar 2, 2010 | 09:24 PM
CD5_530's Avatar
so the ones in the link below will work for my 94 ex
http://www.lightningmotorsports.com/.../i-217726.aspx
Old Mar 3, 2010 | 03:35 AM
Yes, BUT before you buy anything though, go on HondaSociety and search through the Fifth Gen section there, there was quite a informative thread on the topic.
The arm is shorter to start with so you correct camber that way and you have the adjustable ball joint.
I don't believe any modifications were needed for it to clear the wheel well.
Old Mar 3, 2010 | 09:32 AM
CD5_530's Avatar
ok thanks for the good info ill start searching
Old Mar 3, 2010 | 12:05 PM
94@ccordlx's Avatar
for the rear just use the old washer trick. go to lowes or home depot or whatever and get the right thread and grade bolt that is longer and get you some good washers and put however many you need back there. that what i did on my old DA and ill be doing it on my CD5 as well. As for the front get the non adjustable anchor style for better reliability or if you need more or less adjustment get the ingalls kit
MyIntegra
Apr 12, 2010 01:26 PM
kryptic
Aug 18, 2006 12:25 AM
blk94gsr
Feb 11, 2006 07:23 PM
93dx--hatch
Feb 19, 2003 10:01 AM
vteg
May 10, 2002 07:04 PM
